Old June 21, 2010, 08:37 AM
Question What's a good P/S for a Radeon 4890?
Hi all,
I've been trying to upgrade my video card from a Radeon 1650SE to a Radeon 4890. I bought a 650w Power King P/S, but it turns out it's not powerful enough. I was wondering if anyone could recommend a power supply that would power a 4890?
System stats: Acer Aspire E380 with a Radeon 1650SE video card, and a Samsung SyncMaster 226BW monitor.
Also, there's another 2 gb of ddr2 ram, and it is running on Windows 7 Pro 64 bit.
Old June 21, 2010, 08:57 AM
did you already buy the video card? a decent 400 watter will do plenty.
Old June 21, 2010, 02:58 PM
What is your budget? I assume you're buying from Canadian retailers? Have a look at these options:
Newegg.ca - Antec NEO ECO 520C 520W Continuous Power ATX12V v2.3 / EPS12V 80 PLUS Certified Active PFC Power Supply
Newegg.ca - SeaSonic SS-500ET Bronze 500W ATX12V v2.31 80 PLUS BRONZE Certified Active PFC Power Supply - Power Supplies
For the love of god, he's asking for suggestions. If he knew what a decent 400W PSU was then he wouldn't be here. I know you're trying to be helpful, but if you're going to post then at least give some examples.
Old June 21, 2010, 03:25 PM
Silvgearx's Avatar
and most 400w only have 1 PCIE 6pin
Here is another.
NCIX.com - Buy Antec Earthwatts 650W Power Supply ATX12V V2.2 EPS12V Active PFC 80PLUS 120MM Fan - EA650 In Canada.
Old June 21, 2010, 03:40 PM
the card does come with a molex to pci-e, if not pick one up for a buck.
Old June 21, 2010, 09:35 PM
OK, thanks for your replies. I will consider these that you've posted.
Old July 4, 2010, 07:00 PM
Unhappy Still doesn't work
OK, I bought that Earthwatt 650w Antec power supply, but I'm getting the same thing. It still seems it is not getting enough power. This really sucks, I should have bought a more powerful power supply. It turns out this one is too weak. Very bad recommendation, I'm out $100 now.
Old July 4, 2010, 07:09 PM
or somethign else is the problem.....
Old July 4, 2010, 07:32 PM
It was not a bad recommendation, it is not a bad PSU, and you definitely have enough power. The problem is being caused by something else.
Old July 4, 2010, 07:36 PM
stoanee's Avatar
I agree with Zero, you have plenty of power. What exactly is your problem?
heatware
[FS] XFX Radeon 4890 (2x) rogueblade Buy/Sell & Trade 8 April 8, 2010 03:20 PM
ATI Radeon HD 4890 ROUNDUP Comment Thread SKYMTL Video Cards 38 July 28, 2009 03:51 PM
GTX 285 2G version or 2X Powercolor Radeon HD 4890's (1G each) Gameplaywarrior Video Cards 33 July 9, 2009 11:42 AM
