Old June 17, 2010, 02:57 PM
Default Sapphire 5870 Vapor-X 2GB vs Toxic 2GB
Have a Toxic on order somewhere but they are out of stock... if I roll back to the Vapor-X what do I lose apart from some minor overclocks on the core and the memory? The Vapor-X is 2 cheaper than the Toxic so I'm guessing there isn't all that much difference?
I can find Vapor-X reviews and I can find Toxic reviews but the two always seem to use different test systems so the fps results aren't really comparable are they? I'm guessing there would only be 1 or 2 fps in it anyway and I'm planning to run everything at max 1920x1200 but kinda like the idea of the extra mem and don't intend to upgrade again for a few years at least.
It really is between these 2 cards - I want the best 5870 I can get that will last for a while... But the place I'm buying from literally has no idea when the Toxic will be back and they have "10+" Vapor-X in stock. Is there something inherently wrong with the latter that means people don't want them?
Old June 17, 2010, 03:15 PM
SugarJ's Avatar
I wouldn't call the overclock difference minor. The Toxic is 925mhz vs. 850mhz on the Vapor-X. That's 9 percent higher on the Toxic than the Vapor-X, although you probably wouldn't see a 9% difference in frame rates between the two.
It depends on how badly you want the Toxic. I think they are limited in production numbers, because of the overclock. I don't think there's anything wrong with the Vapor-X editions at all.
Old June 17, 2010, 03:32 PM
OK thank you, yes looking at the overclock again it isn't that minor at all. :) I do badly want the Toxic but am realising that I can make do with the Vapor-X (if I even need that). Thanks for the reply - maybe I wait til Monday to see if they will know when the Toxic will be in.
Sapphire HD 5870 2GB Toxic Edition Review Comment Thread SKYMTL Video Cards 30 April 10, 2010 07:27 AM
Sapphire Introduces 2GB HD 5850 Toxic Graphics Card FiXT Press Releases & Tech News 7 March 25, 2010 11:10 PM
Sapphire HD 4890 2GB Vapor-X Review Comment Thread SKYMTL Video Cards 12 September 21, 2009 08:20 PM
