-   -   3870 for Starcraft II (http://www.hardwarecanucks.com/forum/video-cards/33168-3870-starcraft-ii.html)
Dr_BenD_over June 14, 2010 05:35 AM
The guy's presently using a integrated 6100 or something like that. Is a 3870 enough or should the sights be set a little higher?
It's a lower end Dell system so it probably only has a 300-350W PSU. Would a 5770 be to much?
Rison June 14, 2010 05:47 AM
Although a 5770 is a good GPU, the min power supply is 450W.
Most 5xxx series ATI cards need 400W+. If the system it's going in has a standard 24 pin atx power connector, you could always get a new power supply for it.. but by the sounds of things, you'd be overkilling the current hardware with the newer GPU.
geokilla June 14, 2010 05:49 AM
I've read that Dell PSUs are a beast, so it should definitely be able to handle the mid-range GPUs. However unless he's getting a 3870 for cheap, I'd suggest a 5670 or 4830. I think those are the better options as they're newer and can future proof his comp a bit.
Dr_BenD_over June 14, 2010 06:03 AM
The 3870 could probably be had for $50 but he wouldn't be against getting a new PSU as well if the framerates are there.
_dangtx_ June 14, 2010 06:47 AM
if its a good one, i.e. delta or such, it will take an 8800gt, given cpu is not a hog itself to booth with. best investment for that pc.
Dr_BenD_over June 14, 2010 07:01 AM
I think I've convinced him to go with a GT 240
NCIX.com - Buy MSI GT 240 550MHZ 1GB 1580MHZ DDR3 PCI-E VGA DVI HDMI HDCP Video Card - VN240GT-MD1G In Canada.
No PSU worries there.
Zero82z June 14, 2010 10:41 AM
The PSU will be enough to handle any reasonable video card, so that really isn't an issue. But a GT 240 would be a good choice.
feerof June 17, 2010 11:56 PM
3870 is good enough... i'm currently using one, and i've played sc2 with high settings.
CroSsFiRe2009 June 18, 2010 12:00 AM
Stick with the 3870. I've had friends play on integrated graphics of all things with SC2. A 3870 should be more than enough for it
phoenixrage June 18, 2010 11:28 AM
http://www.tomshardware.com/reviews/...mark,2611.html
