Old June 13, 2010, 12:13 PM
i dont know..pick up 2x5770 used for 250 or less?
or do that with one 5850
Old June 13, 2010, 12:18 PM
Pine's Avatar
One 5850. Definitely. Non-crossfire graphics solutions are much easier to handle in the power and heat area, and generally produce less problems. Overclock it even on the stock cooling, and you've almost got a 5870.
Old June 13, 2010, 12:57 PM
geokilla's Avatar
Originally Posted by micul View Post
I think i will go for a HD5830. From what i read on some reviews the difference between HD5830 and HD5850 is not that big.
Worst purchase ever. I'd spend a bit more for the ATI 5850. However for $190, gogogo!
Originally Posted by martin_metal_88 View Post
the problem is that the 5830 is like 5% faster then a 5770...so if OP wanted 2X 5770 he will be sad with a single 5830...so just get a 5850 and don't waste more time.
With new drivers, I think the performance of the GPUs increased a bit. I think it's a worthwhile purchase for $190. Heck I'm tempted too.
Old June 13, 2010, 01:05 PM
martin_metal_88's Avatar
the 5770 performance increase to with 10.4 ( 10.5 was a bug fix so no real gain ) So the performance is still around the same.
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
Old June 13, 2010, 07:22 PM
BootlegUsher's Avatar
How well do 5830's crossfire? That deal is awesome and I second crossfire 5830's for moar power!
Old June 13, 2010, 07:27 PM
Caldezar's Avatar
Or you could grab a Sapphire 5770 since they're only $158 on Newegg.ca right now...
Sapphire - SAPPHIRE Radeon HD 5770 (Juniper XT) 100283L Video Card - 100283L
Old June 13, 2010, 07:51 PM
dring ati slash prices makes you think soemthings around the corner
question is..on what side? ;)
Old June 13, 2010, 08:00 PM
Pine's Avatar
Well, I'd say they crossfire the same as any other card. The heat is a little more, they take a little power (though that shouldn't be a problem), they give more power, sometimes they're glitchy in new games before new drivers come out. S'about it.
  #19 (permalink)
Old June 13, 2010, 08:45 PM
My 8800GT died yesterday so I've got one of these on the way. Budget was tight and this was the most I could justify spending.
On a side note, baking my 8800gt in the oven for 10 minutes did not fix it, which is too bad. I've heard of lots of people having success reviving dead cards that way.
  #20 (permalink)
Old June 13, 2010, 08:49 PM
if its a bfg you know what to do, i would have said without looking at your system specs..wait you do have a bfg
X58 vs P55 build decision Writer CPU's and Motherboards 8 January 8, 2010 06:58 PM
CRTC Decision lcdguy Reviews & Articles from the Web 9 September 30, 2009 08:29 PM
CRTC decision Inik Off Topic 64 August 23, 2009 12:59 PM
Case Decision shayan288 Cases 26 August 13, 2009 11:40 AM
The final Decision on my New Board Soultribunal CPU's and Motherboards 15 December 17, 2008 09:19 PM
