Old June 6, 2010, 04:29 PM
Default 5850 running too hot?
Hello, my xfx 5850 is running hotter than I had expected at idle (~50C), and jumps to around 75C on load. Room at around 25C
From reviews, it seems it is a bit hotter than what most 5850s are running at, and I was thinking of reapplying the TIM on the card.
Is this a difficult process? Would I see much of an improvement? I want to keep my fan as low as possible, and don't want it getting too loud. I don't really want to spend another $50+ on 3rd party cooling.
Now, in order to do this, I know I just have to unscrew all the screws in the back, clean stock TIM, reapply, rescrew. The one thing I was concerned about is the thermal tapes. Would they need to be replaced once they come off? Any video/picture guide I can follow to make sure it goes okay?
Thanks!
Old June 6, 2010, 04:56 PM
Digikid's Avatar
What is your card exactly?
Old June 6, 2010, 04:57 PM
And in which case is it housed in?
"What is the colour when black is burnt ?" - Neil Young
Old June 6, 2010, 05:15 PM
just replace tim dont worry about the tape just dont get it dirty
and adjust fan speed to 30%+
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old June 6, 2010, 05:46 PM
75C at load isn't that much. I personally wouldn't even bother.
Old June 6, 2010, 05:51 PM
rapmaster's Avatar
75C pfffff, you should see how hot my 4890 get, 75C is fine.
Quando omni flunkus moritati
Old June 6, 2010, 05:54 PM
Pankie's Avatar
For a 5850 it's a little above average. Is it overvolted/oc'd at all? Fan speed? Whats the air circulation like around it. Changing the TIM might help a little bit but addressing the other issues first may yield better results.
I'd say turn up the fan speed and see how that works, and then if you can mount a fan inside the case to shoot cool air on the back of the pcb/in the intake. Do what you can, but replacing the TIM will l probably not do much.
Old June 7, 2010, 12:37 AM
yeah, i'm a little worried because it's on an open bench right now, with fan at 35%+ on idle. still around 55/75+ idle/load.
it is all stock settings, it is the xfx 5850 black edition.
i will try re-doing the TIM.
Old June 7, 2010, 07:56 AM
Digikid's Avatar
With XFX you will be safe redoing the TIM since it will be covered by warranty.
Old June 7, 2010, 07:59 AM
rjbarker's Avatar
In a Case with "proper / efficient" Air Flow would you not get improved Temps over an "Open Bench" ? I would think so...
Classified Ultra SLi "Procyon"
http://i30.photobucket.com/albums/c3...2/DSC02888.jpg
http://i30.photobucket.com/albums/c3...2/DSC02889.jpg
Evga 4.2 Ghz Club....
First WC Try finally running scruff Water Cooling 12 June 27, 2010 07:06 AM
Is my 5770 running hot? krajee Video Cards 6 June 23, 2010 01:17 PM
Q6700 running unusually hot? Connorreah Troubleshooting 6 August 2, 2009 06:21 PM
Hot summer days, hot computer problems. NightRain Air Cooling 17 July 6, 2009 09:11 AM
E6700 Running way too hot. r00tman CPU's and Motherboards 4 July 12, 2007 03:48 PM
