  #131 (permalink)
Old November 29, 2007, 04:17 PM
SKY,
My system is:
ASUS M2R32-MVP
AMD X2 6000+ Processor
2 Gig Ram
2 WD 75Gb Raptors - Raid 0
2 ATI HD3870 - Crossfire
32-bit Vista Ultimate
  #132 (permalink)
Old November 29, 2007, 04:26 PM
Here is my concern.....see the screenshots below. As you can see in CCC, it only shows one video card....when I had two 1950XTX's in crossfire it would show 2. In the device manager shot it shows two RV670's and when I had the two 1950XTX's it would show two 1950XTX Primary's and two 1950XTX Secondary's as display adapters.
  #133 (permalink)
Old November 29, 2007, 07:07 PM
Showing one card in the Display Manager is normal now
Unlocking ATI Overdrive is the only place I found both cards in CCC.
The Crossfire menu will stay if you pull out a card without reinstalling the drives
Phenom X4 9500
ASUS M2R32-MVP
4x 512 Crucial Ballstix DDR2-800
2x HD3850 Crossfire
WinXP 32bit
CAT 7.11
  #134 (permalink)
Old November 29, 2007, 09:13 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
Which drivers are you using? It should say HD3870...NOT RV670.
  #135 (permalink)
Old November 29, 2007, 10:14 PM
I was using 7.11, but I used the ones that came on the disk with the cards per someones suggestion I saw.
I guess they changed the way the drivers work to confuse me. I certainly hope the drivers mature because I can tell you that the 3780's do not have the performance my pair of 1950's had.
  #136 (permalink)
Old November 30, 2007, 06:10 PM
Seeing only one card in CCC is normal. Try running 3dmark06 in CF enabled, and then CF disabled. What kind of scores are you getting? Should be somewhere in the 10000 (non CF) to 13000 (CF) range without overclocking the card memories. Are your PCI slots configured for their maximum bandwidth (not familiar with your mobo, but I assume you would get 8x for each of the two cards in CF).
  #137 (permalink)
Old December 5, 2007, 04:58 PM
Theres a patch out for Vista for dual vid cards and performance issues
Graphics performance can be improved in certain multiple-GPU scenarios on a Windows Vista-based computer
If all else fails, you might try updating your motherboard bios?
http://www.xtricom.com
  #138 (permalink)
Old December 7, 2007, 10:55 PM
I didn't realize they made 512mb versions of the 3850.
I also read today that there will be a passively cooled 3850.
Sapphire Unveils Passively Cooled Radeon 3850 - TrustedReviews
  #139 (permalink)
Old December 8, 2007, 06:45 AM
SKYMTL's Avatar
HIS Radeon HD 3850 ICEQ3 Turbox 735MHZ 512MB 1.96 GHz 256BIT GDDR3 PCI-E 2XDVI HDTV Out Video Card - DirectCanada
Lookie what I found!!
  #140 (permalink)
Old December 8, 2007, 10:17 AM
BALISTX's Avatar
That's cool but might as well spend an extra $13.00 and get the 3870 for $232.20.
Palit Radeon HD 3870 512MB GDDR4 PCI-E Dual DVI-I HDCP HDMI HDTV Out Video Card - DirectCanada.
Heatware
HWBOT
ATI HD3870 X2 1GB Comment Thread SKYMTL Video Cards 126 June 7, 2008 07:11 AM
Thermaltake TMG A1 Review Comment Thread SKYMTL Water Cooling 5 January 16, 2008 09:14 PM
Comment Thread for Thermaltake TMG ND5 Review SKYMTL Video Cards 5 October 25, 2007 05:11 AM
