  #21 (permalink)
Old May 31, 2010, 06:58 PM
they said that for now the first batches are 470's that have disabled units(ram as well)
makes sense. remember the first duallies that now dont unlock anymore for amd becauset ehres nothing to unlock?
if i were you and could find a point of view id buy it on the spot
  #22 (permalink)
Old May 31, 2010, 06:59 PM
I highly doubt the validity of that article, the chances that they were able to unlock ALL the shaders, ALL the extra RAM, ALL of the RAM bandwidth, and then get an overclock that big on the first card they tried would probably be less than 1%.
  #23 (permalink)
Old May 31, 2010, 07:00 PM
rapmaster's Avatar
wouldn't that brick the card if it doesn't work, and void the warranty?
Quando omni flunkus moritati
  #24 (permalink)
Old May 31, 2010, 07:01 PM
possibly, but on the very first batches till nv makes it impossible to unlock? id try my luck :p
make sure you erase eprom,then flash. if you reboot its over..unless you have a pci card handy.
they also say to get the reference boards, any custom design will have no extra ram to enable like on that unit (expense)
Tags
465 , evga , nvidia , zotac
Rumored GTX 465! Silvgearx Rumor Mill 41 July 10, 2010 02:09 PM
W555 EVGA SR-2 Pre Order 600 $ USA ZZLEE CPU's and Motherboards 15 June 2, 2010 09:48 PM
Xbitlabs - GTX 465 Review??? CroSsFiRe2009 Reviews & Articles from the Web 41 May 31, 2010 09:01 AM
Evga 8800 gt: Nvidia VS Evga drivers TwystedMonkey Video Cards 4 September 1, 2009 01:57 PM
