Originally Posted by 71Baker Hi all. First time poster , long time fan of Hardwarecanucks.
As the title says , i bought a cheap Radeon 5750, the manufacturer's name is Vero Graphics.
I figured , well its cheap so what the heck...
Came home and i found something i haven't seen in a long time. A Gfx card with no extra powercoupling!
I googled it , found nothing, Went to Vero graphics homepage , found nothing , nothing more than their recommendation to use 2 pci-express connectors for this card.. 8) I think they just made a generic page for all of their cards as their picture shows no connector either...
Anyway , i plugged it in to see if it worked and if it was indeed a 5750, installed new drivers and , well , i can't see anything wrong with it , it has worked now for like 2 months and not even one hangup in even long gaming-sittings.
Could this be correct? Does any other manufacturer sell cards w.o pci-x conn ?
And finally , could i run this in Crossfire? The outside of the box says it has CrossfireX Technology , there is the regular CF connectors on the top end of the card and so on...
From what i have read 5750 has a really low power consumption but really , THAT low ?
Edit: I have since i posted this put in info of the rest of my computer in my system specs |
never heard of the company up here.
may be a lower powered unit. drop everest or gpuz and check clocks.
your cards page says
HD5750 -VERO™ launch the Radeon HD 5750 with complete DirectX 11 support and the world’s most advanced graphics, display and memory technologies.
Product Specification
• Graphic Processor: ATI Radeon®HD5750
• Memory: DDR5 1GB
• Memory Interface: 128Bit
• Core Clock: 850 MHz
• Memory Clock: 4800 MHz
• Output: VGA + DVI
• Bus Type: PCI-Express 2.0 x16
from hexus
from tpu :
| GeForce
9600 GT | Radeon
HD 4830 | Radeon
HD 4770 | GeForce
GTS 250 | Radeon
HD 4850 | Radeon
HD 5750 | Radeon
HD 4870 | Radeon
HD 5770 |
| Shader units | 64 | 640 | 640 | 128 | 800 | 720 | 800 | 800 |
| ROPs | 16 | 16 | 16 | 16 | 16 | 16 | 16 | 16 |
| GPU | G94 | RV770 | RV740 | G92 | RV770 | Juniper | RV770 | Juniper |
| Transistors | 505M | 956M | 826M | 754M | 956M | 1040M | 956M | 1040M |
| Memory Size | 512 MB | 512 MB | 512 MB | 1024 MB | 512 MB | 1024 MB | 512 MB | 1024 MB |
| Memory Bus Width | 256 bit | 256 bit | 128 bit | 256 bit | 256 bit | 128 bit | 256 bit | 128 bit |
| Core Clock | 650 MHz | 575 MHz | 750 MHz | 738 MHz | 625 MHz | 700 MHz | 750 MHz | 850 MHz |
| Memory Clock | 900 MHz | 900 MHz | 800 MHz | 1100 MHz | 993 MHz | 1150 MHz | 900 MHz | 1200 MHz |
| Price | $80 | $95 | $110 | $140 | $100 | $139 | $130 | $159 |
