Old May 29, 2010, 12:40 AM
Default 5850 Overclockers Thread :D
Haha im not sure if theres already one of these, i checked the search and there didn't seem to be. Anyway whats the highest STABLE overclock that you've managed on your 5850?
I believe you guys so screenshots for verification aren't necessary (unless you want to add them) ;)
I managed 888mhz on the core and 1188 on the mem, but for ABSOLUTE stability i stick to 871mhz core and 1171 on the mem :D
Edit: Heres a good link i found for anyone considering the benefits of overclocking their 5850's:
"Hidden Threat": ATI Radeon HD 5850 Graphics Card Review - X-bit labs
Old May 29, 2010, 09:12 AM
I have a Powercolor PCS+ 5850 and I can do 800Mhz on the core but I can't do 825Mhz on the core, and I have the mem at 1100Mhz
Desktop: Asus Maximus V Gene | 3570K @ 4.2Ghz | 4x4GB G.Skill DDR3-1600 16GBXL 9-9-9-24 | Patriot PYRO SE 240GB SSD | Zotac nVidia 560ti | Seasonic X-460FL 80PLUS Gold Modular Fanless Power Supply
http://feedback.ebay.ca/ws/eBayISAPI...onthelam7&iid=
http://heatware.com/eval.php?id=44147
Old May 29, 2010, 12:34 PM
SneakySnake's Avatar
What app do you guys use for OC'ing the 5850 ?
Old May 29, 2010, 03:33 PM
headsh0t's Avatar
Currently running @ 880 / 1100 at 1.1v stable. Haven't had a need to push it higher yet.
MSI afterburner
Old June 6, 2010, 06:14 PM
ultraman7k's Avatar
so i flashed my XFX to the MSI bios, and I can't unlock the voltage, even after ticking the boxes in MSI afterburner...i guess i am restricted by a non-reference card?
that being said, I am now able to push the clocks in CCC much higher than they were before...but is there a limit that I should be aware of, as I am limited to stock voltages?
Old June 7, 2010, 10:46 PM
C130AVN's Avatar
Greets Gents -
I have a Sapphire hd 5850 1 GB I removed the stock cooler and Installed a Thermalright Spitfire and VRM-R5 Cooler, I run 975/1300 @ 1.225V. My temps in a 25 degree room are 31 at idle and 55 at full load running FurMark @ 1920x1080. I flashed the BIOS with the MSI binaries to unlock the vcore adjustment and I use MSI afterburner to overlock. One thing I would warn against with Afterburner is making a custom automatic fan setting, everytime the fan changes speed you video will stutter like crazy, better stick to a fixed fan speed instead.
Old June 10, 2010, 03:37 PM
I have a question with msi afterburner..
I'm overclocking my 5850 usin afterburner with "enableunofficialoverclocking=1" to get over the 765 limit on the core clock.
But once I set the core clock any higher than that 765, the gpu will constantly stay at the higher speed (ie if I set core clock to 780, then afterburner monitor shows the core clock and mem clock to be constantly max, basically 100% gpu usage even at idle)
why does that happen? I would like it to overclock only wheni start a game to keep temps and fan noise down? Thanks for any advice.
Old June 10, 2010, 05:59 PM
Dr_BenD_over's Avatar
ORB - Compare
And there was a previous thread... say November'ish
If it's stupid and it works, it isn't stupid.
Old June 10, 2010, 07:10 PM
You can make two profiles using MSI Afterburner: one for idle 2d use, and another for 3d use. Just save the clock speeds you want for each one, and configure it accordingly in the settings.
Old June 10, 2010, 07:28 PM
headsh0t's Avatar
Originally Posted by C130AVN View Post
Greets Gents -
That is a frickin crazy cooler man. Huge overclock too. You're stable, in game? Cause I know I've used furmark before and it's stayed stable for over an hour but I'd go play some BFBC and it would fail.... Kind of funny since it's supposed to be a stability test. Same thing goes with Prime 95'ing a CPU though. Could be stable for hours but run some gaming or folding on it and you can watch it fail.
Sapphire Radeon HD 5850 1GB Toxic Review Comment Thread SKYMTL Video Cards 28 June 16, 2010 12:17 AM
Sapphire HD 5850 1GB HD 5770 1GB Review Comment Thread SKYMTL Video Cards 25 February 3, 2010 08:19 AM
XFX Radeon HD 5850 1GB GDDR5 Review Comment Thread SKYMTL Video Cards 33 November 16, 2009 07:57 AM
Calling for the help of extreme overclockers scooter.jay Overclocking, Tweaking and Benchmarking 7 September 4, 2009 08:59 PM
OverClockers Fantasy Football 07/08 3oh6 Off Topic 5 August 23, 2007 01:57 PM
