Old May 27, 2010, 12:12 PM
rjbarker's Avatar
Default Evga GTX 480 Vanilla x 2 SLI - Initial Thoughts
Well folks.arrived home yesterday from my month at work and jumped right into my "new toys" awaiting my attention.
I haven't OC'ed these Cards at all yet ....testing these Cards right now at the "Vanilla Stock speeds".
Here are some basic results.....in the first two tests I have indicated a comparison to a relatively High OC'ed 3X Tri Sli GTX 280 (730 / 1458 / 1275) arrangement.
Testing is all done on my Primary Rig in Signature @ 1920 x 1200 Res (except Vantage)
Noise:
- Set Fans to 65% for idle - no biggie here, barely audible over my several Case Fans.
Temps: GPU #1 42c GPU #2 41c
- All Benchmark Runs Fan set to 75% - audible and about at the level of my previous Tri Sli 280's @ 85%
Note: Fans set to 90% are quite loud, much louder than Tri Sli 280's @ 90% - "wwwoooossshhhh"
All Testing done with the following:
I7 @ 3.83 Ghz (201 Mhz Bclk x 19 Mult)
6GB Doms @ 1612 Mhz (2:8)
HX 1kW
2 x GTX 480 Vanillas @ Stock 700 / 1401 / 1848 - No OC
nVidia Driver: 257.15 Beta
Vantage - PhysX enabled - Default Settings
Tri Sli 280's OC'd (730 / 1458 / 1275) - Max Score: P34K
Sli GTX 480's - Stock Vanilla Speeds - Max Score P36K - Max Temp 68c
FC2 - 3 Loops
1920 x 1200
All Ultra / Very High
8x Anti Aliasing
Tri Sli 280's - Highest Avg FPS 115 (Sorry didn't record Min / Max)
Sli GTX 480's
Min: 103 FPS
Max: 225 FPS
Avg: 143 FPS
Max Temp: GPU #1 - 71c GPU #2 - 64c
Heaven DX11
Shaders: High
Tess: Extreme
Anisotropy: 16
AA: 8
1920 x 1200
Min: 27 FPS
Max: 121 FPS
Avg: 51 FPS
Score: 1275
Temps: GPU#1 - 81c GPU#2 74c
Anyhow, been home only since 7:00 PM last night - so, not much time for complete testing yet, next still will be seeing just how far these Cards can OC and some further Testing.
Would be nice to compliment them with a nice 4 Ghz I7 OC, but this old C1 Stepping I have never been able to get stable at above 3.83 Ghz, no matter how much vTT n vCore I threw at it....oh well.
Perhaps that will be my next upgrade to this Rig, a Hexa Core Gulftown when they're Mainstream editions become available
will be adding an additional 140mm Fans to the TJ09 Side Window this week sometime to help pull Temps down a bit.
will keep everyone posted on OC'ability and results as I "play" around...
Overall, I'm happy with the initial results!!
Cheers
Classified Ultra SLi "Procyon"
http://i30.photobucket.com/albums/c3...2/DSC02888.jpg
http://i30.photobucket.com/albums/c3...2/DSC02889.jpg
Evga 4.2 Ghz Club....
Old May 27, 2010, 12:14 PM
"Quote This..."
Initial thought, overkill.
Black belt in CAPS LOCK.
Old May 27, 2010, 12:18 PM
rjbarker's Avatar
^^^ Thanks Squeets.....appreciate your "constructive Post"...surely you can do better than "OverKill" ;)
ABSOLUTELY its Overkill......whats your point?
Old May 27, 2010, 12:23 PM
fishingfanatic's Avatar
Smile Video Cards
It may be overkill, but I like it!!! This is half the fun of going overboard, because you can. That hexacore would be awesome. It made mine so much better, nothing like overkill. My benching of the 5970s in xfire is pretty basic because I'm still very green behind the gills, hehe. For Unigine, my min/max fps is as follows: 2.7/
288.4 at stock. Awesome!!!
Old May 27, 2010, 12:27 PM
rjbarker's Avatar
Yep...of course its fun......its called "enthusiast"...at an amateur level, certainly not at the level of 3oh ;)
Wonder when / if those Gulftowns will be available $300 - $400 range, certainly not going to drop 1.2K on an "Extreme".....
...trying to figure out what to do with these 2 GTX 280's.....seems to easy to simply sell em..huh.build another Rig - P55 perhaps...
Old May 27, 2010, 01:15 PM
Thumbs up Video Cards
Actually, I kept an eye on ebay of all places. When there was a 6 core near the end of its bidding I swept in at the last minute and got 1 for approx. $720 Cdn. Just make sure you set up a PayPal account if you're gonna try this. It took me 2 wks, but was worth it in the end. Good luck and enjoy the new cards!!!
Old May 27, 2010, 01:38 PM
belgolas's Avatar
Nice mini review. Looking forward to seeing your overclocks as I haven't touched mine till I get temps down.
Sponsor a child!
Fight poverty.
Qoute by Perineum
"ID10T. I just BETCHA he's got 9 toolbars on his web browser right now."
Old May 27, 2010, 07:51 PM
rjbarker's Avatar
First run at OC'ing ....went for an initial fairly aggressive OC...
800 / 1600 / 1975
Max Temps through Vantage run: GPU#1 81c GPU #2 70c - Ambient Temp in room 23c
No artifacts at all while Stressing...huh....now I know my I7 @ 3.8 is holding me back as I was hoping to get closer to 40K
Old May 27, 2010, 08:18 PM
Nice setup, love how a 3.8GHz i7 is the system bottleneck:D
Old May 27, 2010, 08:42 PM
belgolas's Avatar
We need i27 for it not to be the bottleneck. CPU's need a lot more power. Same with GPU's though....
I want MORE POWA!!!!! but can't afford...
Sponsor a child!
Fight poverty.
Qoute by Perineum
GTX 480: To SLI Or Not To SLI, That Is The Question? TheGregster76 Video Cards 22 June 15, 2010 05:47 PM
3-way SLI GTX 480 Test [Hardware.info NL] deathsupport Reviews & Articles from the Web 13 April 21, 2010 12:34 PM
GeForce GTX 480 Supports 4-way SLI? MonsterSound Press Releases & Tech News 4 April 8, 2010 12:25 PM
EVGA Announces GeForce GTX 480 & 470 Graphics Cards FiXT Press Releases & Tech News 0 March 29, 2010 11:02 AM
P6T Vanilla vs Deluxe v2 vs Evga x58 OpTioN CPU's and Motherboards 3 May 22, 2009 09:01 PM
