Old May 26, 2010, 12:26 AM
ultraman7k's Avatar
Default crossfire 4870 or 5850?
So i've got a question.
Currently I am running a XFX 4870 1 GB, and was wondering if it's even worth to crossfire instead of upgrading to the 5850 atm.
Are the performance gains for having 2x 4870 1GB, marginal, or worth it if the card can be had for cheap? This is considering i don't have $$$ for the 5850 and it's hard to come by.
thanks.
Old May 26, 2010, 12:38 AM
Lpfan4ever's Avatar
Since I have a 4870x2 and it destroys games at 2048x1152, often maxed, I'd say a second 4870 would be worth it if it's cheap. If your card is a 512mb version, then it may be a different story. 1GB of RAM for each GPU surely helps.
Originally Posted by encorp
Code:
<firebane> slightly used
Old May 26, 2010, 09:39 AM
it depends. if money doesnt hurt the wallet, and you dont care about power figures and thermals
Old May 29, 2010, 12:30 AM
I'd say that you'd be better of with the 5850, less power consumption, 100% compatability (crossfire still struggles with the ocassional title) and there isn't a maxed out game it cant play with >30 frames. I guess what it ultimately comes down to is whether you're into Direct X 11 games. From what ive seen i can say that they look awesome and you would probably want to have a compatible card for when they come out in force :)
Old May 30, 2010, 05:09 PM
ultraman7k's Avatar
so, i'm trying to justify the purchase....will it be THAT big of an increase in performance if I go from 4870 1gb -> 5850? (possibly thinking of Sapphire Toxic 2gb)
Old May 30, 2010, 05:18 PM
yes. get the regular reference design unless you find something cheaper. oc it.
Old May 30, 2010, 06:33 PM
ultraman7k's Avatar
what about this card?
NCIX.com - Buy XFX Radeon HD 5850 HD585XZAFC 725MHZ 1GB GDDR5 4.0GHZ 2XDVI HDMI Dp DIRECTX11 PCI-E Video Card - HD-585X-ZAFC In Canada.
I notice that it's significantly cheaper, and isn't OC'd like some of the other ones. however, some people on the forums are saying you can't OC this one? is there truth to this?
Old May 30, 2010, 06:38 PM
well id try to get it under 300, i think bewawa had it for...279? the sapphire one if im not mistaken. xfx and their support make up for the difference in price, tough!
Old May 30, 2010, 06:45 PM
ultraman7k's Avatar
yeah I was thinking of ordering the sapphire 1gb vapor-x from bewawa for $353....but i figured this is local and i'd get it right now...but my main concern is will this thing OC to any extent?
Old May 30, 2010, 06:48 PM
Delavan's Avatar
I'd go for the 5850. Don't forget that it matches the performance of a GTX285 in most occasions. The 4870 X2 card is pretty much equivalent to a single HD5870 is most cases, just to give you an idea. BUT an crossfire of 4870 would be noisier and draw more watts (maybe higher temps also) than a single card obviously...
The HD5850 is supporting DX11 also, a nice feature for the future lolz
Sell your actual card and put that money towards the new card.
The XFX you're pointing at sells with Aliens Vs Predator for $319..not bad.
I wouldn't go for any fancy overclocked models...the price point isn't that good, and the whole "2 gigs of RAM" is proven to be useless in 99% of the cases...don't put money on that.
OEMEXPRESS.COM advertises a Saphirre HD5850 for $299 and a HD5870 for $399..
OEMExpress.com - Canada's Source for Computers, Laptops, Parts & More!
They are in Montreal/Edmonton/Ottawa....
i7 4770K @ 4.0GHz / Corsair H100i / MSI Z97A Gaming 6 / 16GB Kingston Hyper X 1.5V 1600 / MSI GTX1070 FE / Samsung 850 Evo 500gb / Corsair Performance Pro 128GB SSD / Intel 520 120GB SSD / WD Black 640 GB storage / XFX 850 watts Black Edition PSU
crossfire 4850's vs. single 5850 ellyo414 Video Cards 17 February 26, 2010 02:54 PM
5850 Crossfire Benchmarks Caldezar Video Cards 3 February 24, 2010 03:43 PM
Should I buy the ATI 5850 or 2x 4850s in Crossfire mode? lsquare Video Cards 20 February 2, 2010 12:11 PM
4870 Crossfire lanken123 Video Cards 3 February 27, 2009 09:57 PM
4870 crossfire MB? magictorch CPU's and Motherboards 16 August 7, 2008 08:50 AM
