Old May 17, 2010, 04:01 PM
Default Cheapest Way to run EyeFinity with the 5770?
I have sitting here in front of me 3 monitors, 2 of which are VGA and 1 that is DVI. I currently have a 5770 and I'm interested in running EyeFinity with the current monitors that I have. What would be the cheapest way possible for me to do so? I was thinking of plugging in both VGA monitors with 2 VGA to DVI converters and using some sort of a DVI to display port converter (read that it has to be "active"?). Feel free to provide links to the converter that would work as I do not want to buy the wrong thing!
Thanks
Old May 19, 2010, 05:48 PM
Something like this would work.
Old May 19, 2010, 06:07 PM
jcmaz's Avatar
You need the same resolution monitors, so 800X600 won't work with 1600X900.
-Plato
Old May 23, 2010, 11:57 AM
I know this, I have done my research. Why would I want 800x600 anyways?
Old May 23, 2010, 04:26 PM
jcmaz's Avatar
This might thread might help you: Mal's Eyefinity Project (Info, Pics, Vids) (Using PASSIVE DP to VGA adapter!) - Overclock.net - Overclocking.net
-Plato
Old May 23, 2010, 04:33 PM
BE A MAN and buy 3 ultrasharp 24 inchers lol. Only put you back about 2.1gs
Old May 23, 2010, 10:21 PM
CMetaphor's Avatar
Quadfather
Unless you get 2407s like i did
Old May 27, 2010, 09:44 AM
canDarian's Avatar
Samsung T240HD are on sale.
Or you can go Dell which have theirs on for 199.
x3 I think you can do this easily.
You never named your DVI monitor if its cheaper then any combination above then you have your answer.
Cheapest way to crossfire two 5770's mrfunnypickles New Builds 8 March 17, 2010 07:56 PM
Cheapest W7 way TimTheEnchanter O/S's, Drivers & General Software 19 February 24, 2010 03:08 PM
Cheapest laptop possible Sushi Warrior New Builds 3 February 2, 2010 06:54 PM
IS a 5770 enought to run eyefinity on 2 x 22" MarkOne Video Cards 1 November 19, 2009 11:45 AM
cheapest/best for oc ? Jim CPU's and Motherboards 9 June 3, 2007 12:12 PM
