Old May 16, 2010, 12:49 AM
Default Is my 5770 running hot?
I've had it for about three weeks now, and I haven't overclocked it. CCC says the fan is at 50% speed and it runs at ~50C at idle. My case is an antec 900 - currently with only the top fan running at low speed.
this one
Old May 16, 2010, 12:58 AM
burebista's Avatar
My HD5850 sits at 46C with fan at 21%. 23C room temperature.
In idle do you have 2D frequencies/VID?
If it ain't broke... fix it until it is.
Old May 16, 2010, 01:58 PM
Can you dumb that down for me? What are these 2d frequencies/vid?
I just turned on the remainder of the stock case fans on low speed in my 900 and it's running 46-49C at idle now. Room temp is 23C on average, if that matters.
Old May 16, 2010, 02:09 PM
headsh0t's Avatar
Well, most important thing is your load temps. What's the max temp you get when your GPU is being stressed?
Old May 16, 2010, 02:14 PM
burebista's Avatar
In 2D you should have lower frequency and voltage.
Something like my screenshot.
Old June 23, 2010, 10:51 AM
More importantly - I think we need to know your max / load temps. If you run HW monitor. ( just search cpu z - it's on their website. ) and play some intense game for awhile or run a GPU stresser . . . what's the max temps your seeing? Seeing any artifacting / problems in games?
Old June 23, 2010, 01:17 PM
jcmaz's Avatar
Its pretty normal on stock frequencies. My 4850 is approximately 45* degrees without 2d clocks.
Wise men speak because they have something to say; Fools because they have to say something.
-Plato
HD 5770 technix Video Cards 2 March 9, 2010 09:59 AM
[FS] 5770 V2 mattlef Buy/Sell & Trade 2 February 25, 2010 05:36 PM
Q6700 running unusually hot? Connorreah Troubleshooting 6 August 2, 2009 06:21 PM
Hot summer days, hot computer problems. NightRain Air Cooling 17 July 6, 2009 09:11 AM
E6700 Running way too hot. r00tman CPU's and Motherboards 4 July 12, 2007 03:48 PM
