Old May 4, 2010, 09:10 PM
JD JD is offline
Default HD5870 with 8800GTS for PhysX
Just thought I'd share this with you guys...
Rather simple process, not really any more difficult than installing a 2nd GPU.
  1. Once the card is in and your back into Windows install the latest NVIDIA drivers (197.45 in this case), and don't restart afterwards.
  2. Install this "patch": Hybrid PhysX mod v1.03 (No, it's not a virus or anything, some AV software may detect it as a false positive though), click the Cake button.
  3. Create a fake monitor (or I guess you could attach to your VGA input on your LCD) by opening Screen Resolution. In the Display drop-down menu, select "Available display output on: NVIDIA". Then in the Multiple Displays drop-down, select "Try to connect anyway on: VGA"
  4. Open up NVIDIA control panel and enable PhysX.
  5. Restart.
  6. Enjoy PhysX action!
I did this under Windows 7 x64 with ATI Catalyst 10.4 WHQL installed beforehand.
Granted I only used an old 8800GTS 320M that I had lying around. Performance gains are fairly noticeable in PhysX applications though. However comparing to somebody with a GTX470 and i7 920 @ 4.2GHz as well, my Vantage CPU score doesn't get close to his. He's up in the 67k range and I'm only at 42k.
Also I hear NVIDIA is really trying to prevent this, so it's probably best if you want to do this, do it soon and don't bother updating your NVIDIA drivers ever again. GenL (creator of the patch) is unsure himself as to the future of things. He's already had to work around various NVIDIA checks to see if ATI cards were in the system from what I've read.
And I believe the original PhysX PPUs have been dropped from the latest PhysX software as well, so they no longer work. And before that, apparently they didn't work when ATI cards were detected either. From the sounds of it though, using this same patch can fix that up for you.
Here's some quick benchmark comparisons:
FluidMark - Software PhysX
FluidMark - Hardware PhysX
3DMark Vantage - No PhysX
3DMark Vantage - With PhysX
Anyways, best of luck if you end up trying it.
Old May 4, 2010, 09:31 PM
depending on main card, even an 8500/9500 gt will make a difference. 8800gt or up should be more than sufficient on a budget.
Old May 5, 2010, 07:14 AM
Varroa's Avatar
I am doing this with a 4890 and a 9600GSO (96 shader version) and it works great! Some games will enable special effects when a physX card is installed (Mirror's Edge), some have add-in levels you can play (UT3). Some like Batman Arkam Asylum just run better. Games like Borderlands can be forced to use PhysX as well since then use the UT3 engine.
GAMER: Win10 Pro x64, I7 8086K (corsair H110i), Asrock Z370 Taichi, EVGA GTX 1080 FTW, Gskill 4 x 8 GB DDR4 3200Mhz, Samsung 970 EVO 500GB M.2. NVME SSD, Western Digital Blue 1 TB M..2. SSD. Crucial M4 256GB, Mushkin 480 GB ECO SSD, HX750W, Sound blaster Z, & Phanteks Enthoo Pro M
Lenovo Ideapad Y510p: i7-4700MQ 2.4GHz (undervolted by 80mV), 16GB DDR3L-1866MHz, Intel GMA 4600HD / SLI'ed Nvidia Geforce GT 755M 2GB GDDR5, 240 GB Crucial SSD, 128GB M.2 SSD, 15.6" HD+ Glossy LED
Old May 5, 2010, 08:59 AM
we'll need a review upon this second card physix thingie(regular gfx)
...i mean if a rather small/cheap card can make the difference.
Old May 5, 2010, 09:43 AM
Dr_BenD_over's Avatar
Fallen Folder
"Can I use an NVIDIA GPU as a PhysX processor and a non-NVIDIA GPU for regular display graphics?
No. There are multiple technical connections between PhysX processing and graphics that require tight collaboration between the two technologies. To deliver a good experience for users, NVIDIA PhysX technology has been fully verified and enabled using only NVIDIA GPUs for graphics."
PhysX FAQ
Just like SLi was only possible on Nvidia chipsets...
All's well that's Haswell
Old May 6, 2010, 07:11 AM
Dadi_oh's Avatar
I wonder if eyefinity adds any issues for this? I expect not. I just ordered a GT240 from the egg for $65 - $15 rebate so I will be trying this soon. I have a few physx games (mirrors edge, ut3, nfs shift, grid) so it will be interesting to try it out.
And the GT240 is 40nm and low power + quiet so seems like a good match.
Rig1: Q9550 @3.8GHz Vendetta 2, P5Q-PRO, 6GB OCZ Reaper PC2-8500. 5870 1GB, GT240 Physx, Ultra LSP 750W, 2TB internal + 2TB external, 3X23" 5760X1080 eyefinity + GT240 Physx, HAF22 case 3X200mm : Win7 Pro
Rig2: E8200 @3.6GHz Vendetta HSF, DFI P45 LP-JR, 4GB 900MHz, 4870 512MB, X203W 20", Ultra Gladiator Case
Rig3: Q6600@ 3.5GHz H50, P5Q-PRO, 8GB, 8800GTS512, OCZ GameXStream 850W, Samsung 245BW 24" + 19" dual: Snow Leopard + Parallels Win7
Rig4: MAC mini Snow Leopard
Laptop: Macbook Pro 15"
Old May 6, 2010, 07:14 AM
CMetaphor's Avatar
Quadfather
This is of great interest to me: I still love playing Borderlands often (If fact, I might start a 5th character from level 0 even, lol). If this can be checked to see a noticeble improvement in the smoothness or FPS then PhysX will be added to Stygian (although I'll probably try to get my Asus P1 PPU to work before trying an Nvidia GPU).
Edit:
Found the shot below at firingsquad - Apparently frames are doubled in this setup using a PPU. Interesting indeed!
Full Article: PhysX Performance Update: GPU vs. PPU vs. CPU
Old May 6, 2010, 10:35 AM
nice! ok. one more point why nvidia cards hold there value longer :)
Old May 6, 2010, 02:18 PM
MrDiaz's Avatar
This is pretty damn amazing, will definately check out as soon as my 5870 arrives
-- Viva Canada! --
Old May 6, 2010, 03:24 PM
Varroa's Avatar
Edit:
There is an app you can download called "Borderlands Advance Config" that allows you to enable PhysX. There is also a reg setting you can change to do it.
HD5870 Now or Wait JD Video Cards 22 March 3, 2010 04:40 PM
[FS] BFG 260 (216) 55nm Max Core, 8800GTS(112 SP), 8800GTS(96 SP) Apollo4g Buy/Sell & Trade 12 November 21, 2009 07:51 PM
8800gts 512mb 256bit vs 8800gts 640mb 320bit? Bdog454 Video Cards 15 June 12, 2008 07:50 PM
Gaming Shootout: HD 2900xt vs 8800gts vs 8800gts: X-Bit labs Babrbarossa Reviews & Articles from the Web 12 May 29, 2007 04:08 AM
possible to run SLI with an 8800GTS 640 and an 8800GTS 320? Misoprostol Video Cards 10 May 10, 2007 09:19 PM
