  #61 (permalink)
Old July 22, 2010, 08:48 PM
CMetaphor's Avatar
Quadfather
Originally Posted by lowfat View Post
Have you tried them? I could not get them to work. I've been told they fixed the beta drivers.
You don't need to go that far. You just have to make sure it that you enable a false monitor in screen resolution if you are using Windows 7.
Worked jst fine for me with a GTS250. Plays Batman:AA with max physX no problem. But i do have a monitor hooked up on the Gts250.
  #62 (permalink)
Old July 23, 2010, 05:31 AM
Arinoth's Avatar
I may try the 'broken' beta drivers though according to what i have i would assume i have physx unlocked. At least according to that test.
Here I am: here I remain
  #63 (permalink)
Old July 23, 2010, 08:20 AM
lowfat's Avatar
If fluidmark wasn't choppy it should be working. How many SPS did you get? The screenshot never said anything about that.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
  #64 (permalink)
Old July 23, 2010, 03:00 PM
Arinoth's Avatar
Uh what does SPS mean?
  #65 (permalink)
Old July 23, 2010, 03:21 PM
perhaps fps?
  #66 (permalink)
Old July 23, 2010, 04:09 PM
lowfat's Avatar
I assume Spores per second. It shows it during the test. Also what settings are you using for the test? I get a horrible score (i.e. 500).
EDIT: You are using 1.1.1 I am using 1.2.
Mine looks like this.
Queen of Dreams WIP
Big Lian Li
Complete
  #67 (permalink)
Old July 23, 2010, 04:24 PM
Arinoth's Avatar
Want me to run 1.2 and you try to run 1.1.1 and we'll compare the two?
  #68 (permalink)
Old July 23, 2010, 04:36 PM
lowfat's Avatar
I ran the 1.1.1 and I don't like it
It only uses 50% of my GTX285.
Anyways here is the score.
I am going to try the newer drivers to see if either improves.
EDIT: I beleive something is wrong w/ my scores. For some reason the card is using 2D clocks during the tests.
EDIT2: Here is my 1.20 score
EDIT3: Here is my new 1.1.1 score.
EDIT4 : Using the newest WHQL drivers w/ 1.04ff PhysX mod. I didn't enable the false display and PhysX does indeed work. It just doesn't give me a choice to enable/disable in the Nvidia Control Panel. It is nice to be able to use newer drivers though.
Queen of Dreams WIP
Big Lian Li
Complete
  #69 (permalink)
Old July 23, 2010, 06:07 PM
Arinoth's Avatar
Yeah, thats what i'm seeing. Though if i run heaven it doesnt seem to run the 460 at all, does it not have physx?
What other benchmarking software tests a system with and without physx shy of me copying over batman AA and using their in game tester
  #70 (permalink)
Old July 23, 2010, 06:14 PM
lowfat's Avatar
No Heaven benchmark doesn't use PhysX. It is straight up DX11 and nothing else. PCMark Vantage uses PhysX for one of the CPU tests. Not much else out there AFAIK.
Queen of Dreams WIP
Big Lian Li
Complete
HD5870 Now or Wait JD Video Cards 22 March 3, 2010 04:40 PM
[FS] BFG 260 (216) 55nm Max Core, 8800GTS(112 SP), 8800GTS(96 SP) Apollo4g Buy/Sell & Trade 12 November 21, 2009 07:51 PM
8800gts 512mb 256bit vs 8800gts 640mb 320bit? Bdog454 Video Cards 15 June 12, 2008 07:50 PM
Gaming Shootout: HD 2900xt vs 8800gts vs 8800gts: X-Bit labs Babrbarossa Reviews & Articles from the Web 12 May 29, 2007 04:08 AM
possible to run SLI with an 8800GTS 640 and an 8800GTS 320? Misoprostol Video Cards 10 May 10, 2007 09:19 PM
