  #51 (permalink)
Old July 22, 2010, 06:02 PM
Arinoth's Avatar
Well i just can't seem to find/enable physx, everything else is working (drivers and such)
Here I am: here I remain
  #52 (permalink)
Old July 22, 2010, 06:17 PM
lowfat's Avatar
I have my doubts you will be able to until they release a hacked driver for Fermi cards, which I will bet is going to be a long time away since they are still using 196.xx drivers. It isn't as if PhysX is all that important anyways. Only a handful of games support GPU PhysX.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
  #53 (permalink)
Old July 22, 2010, 06:30 PM
but man o man and what a difference you can see when you get it working :) i say its worth the trouble,watts and heat in this summer warmth.
  #54 (permalink)
Old July 22, 2010, 07:13 PM
Arinoth's Avatar
Well according to Hybrid PhysX mod v1.03 / v1.04ff people have gotten the latest drivers working with this patch. Though right now i am having no luck with it.
If i run GPUZ there is a tick for physx under the hd580 as well as when i select the gtx460
  #55 (permalink)
Old July 22, 2010, 07:22 PM
lowfat's Avatar
Did you enable a false VGA display on the GTX460?
Queen of Dreams WIP
Big Lian Li
Complete
  #56 (permalink)
Old July 22, 2010, 07:32 PM
CMetaphor's Avatar
Quadfather
Just fyi y'all: The 257.15 betas direct from Nvidia still do not block ati + physX, so have fun with those
  #57 (permalink)
Old July 22, 2010, 08:20 PM
*gets them
  #58 (permalink)
Old July 22, 2010, 08:24 PM
Arinoth's Avatar
I don't believe the 460s are supported on those as they 'came out' after and if you go to nvidia's website the latest drivers are the only supported ones.
Sort of, i just connected the vga connector from my monitor to it while using the dvi connector off of the 5870
  #59 (permalink)
Old July 22, 2010, 08:25 PM
lowfat's Avatar
Have you tried them? I could not get them to work. I've been told they fixed the beta drivers.
You don't need to go that far. You just have to make sure it that you enable a false monitor in screen resolution if you are using Windows 7.
Queen of Dreams WIP
Big Lian Li
Complete
  #60 (permalink)
Old July 22, 2010, 08:38 PM
Arinoth's Avatar
Well it obviously is running physx at least for this test:
HD5870 Now or Wait JD Video Cards 22 March 3, 2010 04:40 PM
[FS] BFG 260 (216) 55nm Max Core, 8800GTS(112 SP), 8800GTS(96 SP) Apollo4g Buy/Sell & Trade 12 November 21, 2009 07:51 PM
8800gts 512mb 256bit vs 8800gts 640mb 320bit? Bdog454 Video Cards 15 June 12, 2008 07:50 PM
Gaming Shootout: HD 2900xt vs 8800gts vs 8800gts: X-Bit labs Babrbarossa Reviews & Articles from the Web 12 May 29, 2007 04:08 AM
possible to run SLI with an 8800GTS 640 and an 8800GTS 320? Misoprostol Video Cards 10 May 10, 2007 09:19 PM
