Old May 4, 2010, 08:21 PM
Question Which 5850 should I buy.
I'm looking at a normal 5850 (any recommended manufacturer) or a Sapphire Radeon 5850 with VaporX technology. Is it worth the extra money. I will not probably overclock.
Cpu: Phenom IIX4 965
RAM: 4gb
PSU: Corsair Modular 750watt power supply
Case: ANTEC 900
Old May 4, 2010, 09:21 PM
JD JD is offline
You should be fine with any of them really. Only need better cooling if you're overclocking.
Vapor-X may offer some noise reduction too, same goes for other cards with custom cooling. If that matters to you that is.
Old May 4, 2010, 09:26 PM
MonsterSound's Avatar
Default XFX HD 5850 - $306.91
The stock HD 5850 runs cool and quiet so if you're not overclocking you might not put too much weight on the premium cards with enhanced cooling.
Best price and warranty may be more of a concern.
XFX is noted for their double life warranty, but rarely are they the lowest price.
XFX HD 5850 the lowest price I see - $306.91 at onhop is a pretty good price - model HD585AZNFC.
PM NCIX for $5.99 shipping.
2c
Code:
 my Heatware,  RFD &  eBay
MAIN: i5 3570 @ 4.5Ghz wH100 / evga GTX780 SOC / MSI Z77A-G45 / 8gb G.Skill 2133 1T / 30" 2560x1600 / Antec P280 / PCP&C 950w / Intel 520 SSD 240gb / Eclipse / G3-Lazer / z5300 / Win7 Pro64 / APC Xs1300
HTPC : nMedia6000B / AMD X2 4400+ / M2A-VM / Corsair 4GB 800 / LiteOn Blu-Ray / 8800GT / Samsung 46"LCD / 2x2TB / OCZ500 / ATI550 / Wrless Kbrd & Rmte / z-5500 / Win7Pro / APC700
"You must be the change you want to see in the world"
- Mahatma Gandhi
Last edited by MonsterSound; May 4, 2010 at 09:29 PM. Reason: OOS at MemoryExpress
Old May 4, 2010, 09:33 PM
I bought a powercolour, which is probably the cheapest card vendor available. Everything functions as you would expect, had it for over half a year now and not a single problem to report. Like everyone says, it really doesn't matter, only variation is in the coolers (which is irrelevant unless ur looking to overclock) and sometimes core and memory speeds (but you can manually overclock the card urself)
Old May 4, 2010, 09:59 PM
a good idea is to get a stock/ish one wich expels hot air outside the case. even if it doesnt produce monstruous levels like the gtx 400 series, it stil lads up inside thine case :)
Old May 5, 2010, 03:13 AM
Delavan's Avatar
I like XFX and really appreciate the lifetime warranty.
I have the XFX HD5870 reference design and really happy with it.
i7 4770K @ 4.0GHz / Corsair H100i / MSI Z97A Gaming 6 / 16GB Kingston Hyper X 1.5V 1600 / MSI GTX1070 FE / Samsung 850 Evo 500gb / Corsair Performance Pro 128GB SSD / Intel 520 120GB SSD / WD Black 640 GB storage / XFX 850 watts Black Edition PSU
Old May 5, 2010, 06:10 AM
Thank you all guys. I'll take that into consideration.
Old May 5, 2010, 07:19 AM
Personally I'm a fan of the VaporX line as it provides some very nice cooling and allows you to overclock further if you decide too. The Toxic line is also great as them come pre-overclocked and with the VaporX technology. Either way you can't go wrong and it'll really depend on how much extra you're willing to spend over a reference card.
Old May 5, 2010, 07:48 AM
One comment and one question. I think some Sapphire HD 5850 cards are going for $300. But, I notice a lot of various different model names with the last part of the number code changing. Not sure what differentiates them but some are out of stock, others are available.
Now, my question: what's the min. power supply you need? Is it wattage you need to look for or the amp rating on the 12 volt rail?
Specs on 5850 cards state min. power supply of 500 watts. My Corsair HX520 is 520 but the 12v rail is a combined 40A. Does that mean it could take it but it is pushing things? I'm just curious. These cards are probably out of budget and I've been looking at HD 5770 cards, actually. :)
Old May 5, 2010, 08:28 AM
Digikid's Avatar
XFX are the better ones IMHO.
Never had any good luck with Sapphire.
[WTB] HD 5850 darksideleader Buy/Sell & Trade 0 March 2, 2010 06:09 PM
Should I buy the ATI 5850 or 2x 4850s in Crossfire mode? lsquare Video Cards 20 February 2, 2010 12:11 PM
[WTB] WANT TO BUY/Trade for a 5850/5870/5970! BobbyLou Buy/Sell & Trade 7 January 18, 2010 11:19 PM
To buy a 5850 or not to buy... pulling my hair out over this 0o0 Video Cards 20 January 15, 2010 02:42 PM
