<~----> Eyefinity Strangeness....Aero lost... - Hardware Canucks
Old May 3, 2010, 11:21 AM
Digikid's Avatar
Default Eyefinity Strangeness....Aero lost...
I JUST got the adapter for eyefinity....but when I activated it I lose the "Aero" look for Windows 7 and I cannot get it back.
Any ideas?
Old May 3, 2010, 11:30 AM
CMetaphor's Avatar
Quadfather
Any ideas?
Windows Vista/7 doesn't support Aero above certain resolutions - they disable it automatically I think. I know Aero turns itself off on my 3x 24'' when going to max. I'll have to try a few things to force it back on, i think there's a service that turns off that can be forced back on to max it work.
Old May 3, 2010, 11:37 AM
Digikid's Avatar
Also L4D2 does not detect my new res? Trackmania also does not work properly. I KNOW that these games are supported.
What am I doing wrong?
I have three Samsung T240HD's at 1920 x 1200.
Old May 3, 2010, 11:45 AM
CMetaphor's Avatar
Quadfather
All Valve games list custom resolutions under the 16:9 category and NOT the 16:10 one. Check there
Old May 3, 2010, 02:12 PM
Digikid's Avatar
That worked for l4d2. Thanks.
Now about the desktop behaviour....
Old May 3, 2010, 07:23 PM
Digikid's Avatar
Anyone?
Old May 3, 2010, 08:28 PM
kyle_L's Avatar
i run 3 monitors at 2048x1152 and i still have aero active on mine.
im looking for work.
Old May 3, 2010, 08:32 PM
Digikid's Avatar
Yes but that is still considered a "low" resolution.....or medium at least.
Strange how Windows cannot do a glass effect on a higher res.
No matter anymore though.....disabled Eyefinity....made me motion sick in games.
So much for that. :(
Old May 4, 2010, 04:09 AM
When I first switched to a large display (Dell 2405FPW), I had motion sickness as well when playing HL2.
None of that on my old LCD or CRT.
Then I discovered "input lag"/display latency/lag (NOT pixel response time like 5ms GTG).
Judging from this site here, the T240HD has a boatload of it which can definitely contribute to motion sickness.
Product Face-Offs Monitors - DigitalVersus
heatware
Old May 4, 2010, 07:56 AM
zc1 zc1 is offline
I use 6024x1080 and aero is still enabled. Too bad about the motion sickness :(
My Rig (Photos):
Engine:
Q9650 @4.05 GHz on GA-EP45-UD3P // Noctua NH-D14 Heat Sink + 3x CM R4 // Mushkin Blackline PC2-8500 2GBx4 @ 900 MHz
ECU: OCZ Vertex Turbo 120 GB SSD // 3x Seagate Barracuda 500 GB // LG 22X and Philips 20X DVD-RW
Fuel Pump:
Corsair HX1000
HUD: 2x 5870 Vapor-X + 3x SyncMaster 2243
On-Board Video: Hauppauge WinTV-HVR-2250
Chassis: FT02B-W
Projects: [ 5870 CF-X vs Non-CF-X | NH-D14 vs H50 ]
CPU Voltage Strangeness... Draex Troubleshooting 9 February 15, 2010 12:39 PM
im lost Rapid-X Video Cards 4 July 24, 2007 03:42 PM
Aero glass icon and show desktop icon D1GGY O/S's, Drivers & General Software 4 June 6, 2007 03:58 PM
VIA Arena on Windows Vista: Aero explained Supergrover Press Releases & Tech News 3 December 16, 2006 11:41 PM
