Old April 23, 2010, 06:26 AM
Default 2 5770's or 1 5850
From what I have found online I can get 2 5770's for the price of 1 5850.
What do you gurus think. Which is a better setup
upgrading from a 3870x2
Old April 23, 2010, 11:03 AM
headsh0t's Avatar
Two 5770's will outperform a 5850. Their performance level is around a 5870 I believe. If you get a 5850 though you'll use less power and could upgrade to crossfire in the future. I'm actually wondering myself if I should get 2 5770's but can't decide...
Old April 23, 2010, 11:21 AM
gingerbee's Avatar
yup it seems a lot of us are in that boat.
Old April 23, 2010, 11:23 AM
SneakySnake's Avatar
I'd go with a single 5850, since the performance is quite acceptable for pretty much every game, even crysis (mix of high and very high settings, with 2x AA, ~35 fps).
And like headshot said: you can add another 5850 in the future and get incredible performance
Old April 23, 2010, 11:27 AM
gingerbee's Avatar
um your setting mean nothing without knowing res( cause i get higher fps then that outta a 4870 )
Old April 23, 2010, 11:35 AM
went with a MSI 5850 OC'ed version. Wont have it up and running until monday but will do some benchmarking then.
Old April 23, 2010, 10:26 PM
Sorry, forgot that detail, 1920x1080.
Old April 26, 2010, 04:53 PM
I'd suggest 5850 for the sole reason that after you get those 2 5770, if you want more, you're stuck switching them both. However, if you had gotten the 5850, you can now go for double 5850 and get a nice boost :)
[WTT] Folding card for 2X 5770 or 5850 martin_metal_88 Buy/Sell & Trade 19 April 15, 2010 09:46 AM
Need Help Deciding!!! 2 x 5770 or 5850 now and one later? Digikid Video Cards 16 March 11, 2010 08:13 AM
Sapphire HD 5850 1GB HD 5770 1GB Review Comment Thread SKYMTL Video Cards 25 February 3, 2010 08:19 AM
5870 or 5850? Or 5770? And when? Maplicito Video Cards 14 January 2, 2010 08:40 PM
Temperatures: HD 5770 vs HD 5850? jwebby Video Cards 11 October 23, 2009 04:49 PM
