Old April 22, 2010, 02:04 PM
Default GTX480 Vs. HD5870 VaporX
Hello I'm recently been forced to choose between the two card
and I was wondering which would have more bang for the buck
since the 480 is only a $50 price preminum from where I get my parts so I was wondering if I should get teh 480 as oppose to the 5870.
This is for a gaming PC, running on Corsair HX1000W powersource. In an Air cooled Silverstone Raven-01
Thanks
Old April 22, 2010, 02:41 PM
rapmaster's Avatar
Thanks
If you don't mind the extra noise, heat and power consumption, than get the GTX 480.
Old April 22, 2010, 02:58 PM
Arinoth's Avatar
Even though i went with a 5870, if you are looking at a 50$ difference i would go with the 480.
Old April 22, 2010, 03:16 PM
headsh0t's Avatar
The VaporX variants are usually more expensive than reference cards so you could get a 5870 for cheaper providing your supplier carriers different versions of the 5870. The 480 is the better card performance wise though...
Old April 22, 2010, 03:44 PM
MrDiaz's Avatar
The new 5870 from Gigabyte (Super clocked version) seems to kick GTX480 right on its ass
-- Viva Canada! --
Old April 22, 2010, 04:01 PM
fishingfanatic's Avatar
Default 480/5870
I don't know what kind of budget you have, but if you can rob the piggy bank the 5970 kicks everyones $ss.
Ok, a bit insane, but what the hay, you only live once and this baby runs cooler than the 480 as well as draws less power. You save enough on your electric bill to justify this to the little lady, hehe.
Old April 22, 2010, 04:04 PM
Default 480/5870
Ok, a bit insane, but what the hay, you only live once and this baby runs cooler than the 480 as well as draws less power. You save enough on your electric bill to justify this to the little lady, hehe. Well maybe not but it makes a good excuse for being environmentally conscious. After all, it is Earth Day and your doing your part. LOL
Old April 22, 2010, 04:33 PM
must look up a review.
Delavan's Avatar
HD5970 is a little on the expensive side isn't it? also, it's freakin' long!
IMHO, a cheap HD5870 is a good alternative to a GTX480. BUT, if you start talking about the overclocked and custom versions with a higher price tag, not too sure if the ATI is still really worth it over the GTX.
i5 2500K @ 4.5GHz / NH-U12P / P8P67 DELUXE / 8GB Corsair Vengeance Arctic White 1.35V 1600 / 2 x N560GTX Ti Twin FROZR II OC in SLI (8823 3Dmarks11 P-score)/ Corsair Performance Pro 128GB SSD
Old April 22, 2010, 05:08 PM
Default 5970
Yeah it is pretty big, over 12" long. Of course it's more expensive. If you check prices it's about $150 more. Now check benchmarks and one on one it blows everything out of the water. The eyefinity on the ATI cards is pretty good whatever you get. I've always had Nvidia 'til now and don't regret it one bit. Performance is what I go for and the 5970 has it in spades!!!
Like I said, didn't know what your budget was like. Now if you wanted to go six core cpu, the AMD is a mere $300 compared to Intel @ $1100. Decisions decisions.
Fullcover block for HD5870 JD Water Cooling 46 March 25, 2010 02:37 AM
HD5870 Now or Wait JD Video Cards 22 March 3, 2010 03:40 PM
Vaporx 4890 and 7.1 surround FreeKnight Audio 5 January 31, 2010 11:23 AM
[FS] FS:Sapphire VaporX 4890 1GB|4GB OCZ Reaper DDR3 PC3-1600|Clear UV case MarcusFoX Buy/Sell & Trade 4 October 20, 2009 10:08 AM
Waterblock for HD5870? Z Overlord Water Cooling 15 October 11, 2009 09:26 PM
