Old November 2, 2007, 03:12 PM
Default Problems Overclocking.
Ok, I am using Riva to apply the clock, and ATI too to scan for artifacts.
My defaults are 513 Core and 792 Memory. I can't get past 550 and 810 without getting an artifact in the first 8 mins. Is my voltage too low? My max temp was 68 according to ati tool.
Old November 2, 2007, 03:47 PM
Since you can't modify the voltage of a video card with some major trouble what is the stock clocks for your card because some just don't over clock that well.
Old November 2, 2007, 03:48 PM
b1lk1's Avatar
What card is it? If it is a X1950PRO they are notorious for not overclocking much at all if any.
Driving sim: MSI 970 Gaming/FX6300/16GB Corsair DDR3/ASUS CU II R9 290X 4GB/128GB SSD+750GB HDD
Daily: Intel DQ67SW/i7 2600/8GB DDR3/WD 150GB VR+2TB HDD/CU II R9 270 2GB/Xonar D1
Old November 2, 2007, 04:30 PM
MpG's Avatar
MpG MpG is offline
Those are factory clocks for an 8800GTS, and I would normally expect to go beyond those numbers with stock voltage. Your temperatures aren't particularly high (for a GPU). Overclocking is always a bit of gamble, though, and getting things a few degrees cooler can sometimes make a significant difference.
Have you tried upping just the core clocks? Just the memory clocks? It might just be one of those things causing trouble. Beyond that, if you're bound and determined to get higher clocks, you might try a pencil voltage mod, which might buy you a few more MHz?
Old November 2, 2007, 08:59 PM
Sorry I did forget to mention I have an XFX 8800GTS. I will try just one then jut the other. It is not a huge deal if I don't get that much out of it, I jut thought I would eb able to go higher than like 3%...
Old November 2, 2007, 10:16 PM
MpG's Avatar
MpG MpG is offline
Do you have any other fans blowing on the card? Sometimes just a few degrees can make a difference, and have a fan blowing air at/across the back of the card can help out. A lot of cases give you the option of mounting a fan in front of the GPU, to do just that.
Old November 3, 2007, 07:06 AM
Well, I have the Antec 900, So there should be good airflow, but I don't have a fan specifically for the GPU.
NFS: Pro Street Problems cujo Gaming 11 February 22, 2012 09:33 PM
Problems with Overclocking my e8400 Tumdace Overclocking, Tweaking and Benchmarking 66 March 12, 2008 01:44 AM
Big Problems Feff Troubleshooting 9 January 23, 2008 04:24 PM
Problems Overclocking with Gigabyte GA-P35-DS3L DukeNukem Overclocking, Tweaking and Benchmarking 8 December 13, 2007 05:35 PM
More new problems! belgolas Troubleshooting 8 July 20, 2007 08:21 PM
