Old April 19, 2010, 09:20 AM
Default What is better? GTX 275 or 9800 GX2?
Old April 19, 2010, 09:42 AM
Soultribunal's Avatar
You might want to add what resolution you are gaming at and which Games.
ST
Old April 19, 2010, 11:07 AM
artistpavel's Avatar
A newer single GPU is obviously better than a 9800x2 dinosaur that may not even have a driver support.
Old April 19, 2010, 11:21 AM
the reason i ask is because i have been seeing online that the 9800 gx2 is getting better frame rates
Old April 19, 2010, 11:33 AM
wella its a power hog. basically a 9800gt(ahem x) sli
Old April 19, 2010, 12:06 PM
9800GX2's still have full Driver Support.
I think the reason he is asking is because of some reviews out there on the Web which show 280's and GX2's pretty close in Framerates (where as the 275 is a newer Revision of a 280).
Regards,
ST
Old April 25, 2010, 10:26 AM
DerekOldschool's Avatar
I had a 9800GX2 for a couple of years but it ran hot and eventually,even after taking off the metal housing, the thing needed the fans on at %100 during any form of gaming.
Finally, during an install of Windows 7, my 9800GX2 overheated at the "testing video performance" screen and I sent it in to EVGA for an RMA.
I initially replaced the 9800GX2 with one GTX280 and it did not play COD:WAW Nazi Zombies as smooth as the 9800GX2. I run 1920x1200, 4x AA, 16x AS - full everything. It's a powerful card that I have heard folders like.
Now COD:WAW Nazi Zombies doesn't really use a ton of video memory, so I think that as long as you are playing games at a resolution that dosn't use more than the 512M on the 9800GX2, then the 9800GX2 is better (except for the heat issues) But I think the GTX280 catches up in gaming situations that use more than 512M since they generally have 1G of video ram.
Personally, what happened with me is that they sent back a damaged replacement for the 9800GX2 I originally RMA'd, so I got them to send me a GTX280 as a replacement instead. That way, I can probably get another one pretty cheap (or a gtx285) and run SLI which is pretty much as fast as 1 fermi.
I hope this gives you some info for your comparison question.
i7-860 @ 4.2Ghz (1.33v) • EVGA P55 FTW SLI (E657-A51 Bios) • Thermalright ULTRA-120 Trueblack Rev.C • G.Skill Ripjaws 4G DDR3-2000 • Antec 850W TPQ • 2xBFG GTX280 1G SLI • Acer X263W 25.5" LCD • Crucial C4 256G • WD FAEX 1TB • LG DVDRAM GH20NS10 • Thermaltake Kandalf case • Windows 7 Pro x64
E8400 @ 3.96Ghz (1.42v) • EVGA 780i A1 (P08) • ZalmanCNPS9700NT • G.Skill 4G DDR2-1000 • eVGA GTX280SC 1G • Windows 7 Pro x64 • 1xSeagate Barracuda 7200.11 500G
Old April 25, 2010, 07:57 PM
rjbarker's Avatar
GTX 275 by far!!
IF the GX2 happens to function ok with the latest Driver...thats it....nVidia stopped testing Drivers with GX2's ages ago ( from what I remember)....hence no support...
Classified Ultra SLi "Procyon"
http://i30.photobucket.com/albums/c3...2/DSC02888.jpg
http://i30.photobucket.com/albums/c3...2/DSC02889.jpg
Evga 4.2 Ghz Club....
Old April 26, 2010, 03:07 PM
isn't there a directx limitation with the 9800? I think it doesn't do dx10...
Old April 26, 2010, 03:13 PM
SugarJ's Avatar
Sorry, you're incorrect, it does DX10. GeForce 9800 GX2
[WTB] 9800 GX2 waterblock Charloz24 Buy/Sell & Trade 2 March 30, 2010 09:02 PM
another 9800 gx2 problem.... Charloz24 HardwareCanucks F@H Team 2 March 15, 2010 07:01 PM
would one 9800 gx2 count as sli? triumph Video Cards 1 July 25, 2008 09:53 PM
9800 GX2 reviewed by tweaktown. belgolas Reviews & Articles from the Web 7 March 17, 2008 04:40 PM
9800 GX2 clock speeds and oc Babrbarossa Rumor Mill 15 March 5, 2008 10:53 AM
