  #21 (permalink)
Old November 1, 2007, 02:47 PM
donimo's Avatar
Originally Posted by omgwtf View Post
Bios temperatures...the temperature that is indicated by the bios?
So I would now assume you are inquiring about the CPU and system temps as opposed to the graphics card temps this post is mainly about?
I use easytune for the cpu/system temps and they are the same as bios temps
if you don't mean cpu/sys temps then I have no idea how to check gpu temps with the BIOS...
Mobo GA-Z77X-UD3 CPU i5-3570K stock RAM:2x4GB Patriot Viper 1866 1.5v GPU:XFX HD6850 BE + Gigabyte HD6850 @820/4400MHz Case:Bitfenix Raider w/2x 200mm + 135mm PSU: Corsair HX620
  #22 (permalink)
Old November 1, 2007, 03:03 PM
Shadowmeph's Avatar
Wow those temps are cool for what you have for a setup
  #23 (permalink)
Old November 1, 2007, 03:16 PM
omgwtf's Avatar
Oh yes..that's right..my fault :(
Memento mori
  #24 (permalink)
Old November 2, 2007, 02:14 PM
donimo's Avatar
I dunno, everest and rivatuner both give me the same numbers, atiTool wont work for some reason???
I guess its just the best cooler in the whole world, or something is buggered with my temp monitor....
time will tell?
  #25 (permalink)
Old November 3, 2007, 08:46 PM
donimo's Avatar
So I got ATI tool working, same thin 30 idle and 37 using the built in heat-up test, so I guess this thing friggin rules...
or my temp sensor somehow needed the stock cooler (makes no sense to me?)
YAY?
Weird Spin up noises Cptn Vortex Storage 8 March 17, 2008 06:38 AM
Accelero S1 on 8800GT Hitikiro Air Cooling 8 December 17, 2007 08:53 PM
Arctic Accelero S1 enaberif Member Reviews 14 October 31, 2007 02:20 PM
NEED HELP with a Biostar Motherboard on Vista 64 (weird bug) db23 Troubleshooting 3 October 1, 2007 02:08 PM
Overclocking E6600, weird results dosmond Overclocking, Tweaking and Benchmarking 4 June 24, 2007 10:12 AM
