Old October 31, 2007, 08:26 PM
Shadowmeph's Avatar
Originally Posted by donimo View Post
Hi, I have been a lurker till now, but this baffles me so I thought I would ask, thanks in advance!
I just installed an Arctic Cooling Accelero S1 with the turbo module fans option on my Diamond x1950pro and got some "too good to be true" numbers out of it.
With the stock cooler I measured temps with RivaTuner while running 3dMark06 and got:
- 50-52*C idle
- 75-80*C load
After the install of the S1 and turbo's I get:
- 29*C idle
- 37*C load
I did the tests back to back, the room is about 20*C its in and the numbers just seem way too low. Its in an Antec Sonata 3 case with a noctua 120mm exhaust fan running at 800rpm and an antec tricool set on low speed on the back of the hard drive bays. A/C freezer &pro CPU cooler, Noctua passive chipset cooler To tell you the truth all my temps seem too low:
- CPU= 27*C idle, 38*load with 10 copies of cpu burn running (not the best test, but still)
- HDD0= 25*C, HDD1= 30*C
- System is at 32-37*C only one that seems normal...
Any feedaback or ideas or just count my blessings?
Where is the temp probe on an x1950pro?
I am not sure what your set up is? Pentium 4 or 2 core 4 core?
Old November 1, 2007, 07:56 AM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Yeah OMGWTF xmas is coming BUT as an added bonus so it my b-day...4 days before xmas to be exact. Sooooo I think it's gonna be a hard christmas for my credit card
This may explain why the lyrics to "disco inferno" is stuck in my head
"Burn baby burn! - Disco inferno!
Burn baby burn! - Burn that mama down"
AkG
Old November 1, 2007, 08:48 AM
donimo's Avatar
e6750 core 2 duo
Mobo GA-Z77X-UD3 CPU i5-3570K stock RAM:2x4GB Patriot Viper 1866 1.5v GPU:XFX HD6850 BE + Gigabyte HD6850 @820/4400MHz Case:Bitfenix Raider w/2x 200mm + 135mm PSU: Corsair HX620
Old November 1, 2007, 08:50 AM
donimo's Avatar
Originally Posted by SKYMTL View Post
Jesus. Have you tried ATItool?
I can't get it to work, maybe its because I just upgraded to the catalyst 7.1 drivers and it doesn't see them yet? But it says it doesnt have a driver, try rebooting, so I do, then I get the dreaded "vista has shut down your program" BS response I get FAR too often...
Old November 1, 2007, 09:01 AM
donimo's Avatar
I also left the backplate from the stock cooler on as I could make it work with some longer screws I had, so I really have an "Accelero S1 XT Pro KO edition"
Old November 1, 2007, 12:51 PM
omgwtf's Avatar
the bios temps are the same?
Memento mori
Old November 1, 2007, 01:11 PM
BALISTX's Avatar
My birthday is on the 19th of Dec.
Heatware
HWBOT
Old November 1, 2007, 02:34 PM
donimo's Avatar
How do you check the bios temps? sorry, new term to me, no comprendez?
  #19 (permalink)
Old November 1, 2007, 02:44 PM
omgwtf's Avatar
Bios temperatures...the temperature that is indicated by the bios?
Memento mori
  #20 (permalink)
Old November 1, 2007, 02:46 PM
Its a video card not CPU :P You can't check temps in bios :P
Weird Spin up noises Cptn Vortex Storage 8 March 17, 2008 06:38 AM
Accelero S1 on 8800GT Hitikiro Air Cooling 8 December 17, 2007 08:53 PM
Arctic Accelero S1 enaberif Member Reviews 14 October 31, 2007 02:20 PM
NEED HELP with a Biostar Motherboard on Vista 64 (weird bug) db23 Troubleshooting 3 October 1, 2007 02:08 PM
Overclocking E6600, weird results dosmond Overclocking, Tweaking and Benchmarking 4 June 24, 2007 10:12 AM
