Old April 13, 2010, 08:23 AM
Sui's Avatar
Sui Sui is offline
Default looking for the best slient PCI-E GPU in current market
not for gaming purpose but has to be better than EN8400GS (which currently being used in my PC) and do not require HDMI
TIA
Sui
Hi there... I am new to HWC! Feedback:
Heatware | RFD | HoFo
Old April 13, 2010, 08:31 AM
CMetaphor's Avatar
Quadfather
How about a 9800GT passive?
Newegg.ca - GIGABYTE GV-N98TSL-1GI GeForce 9800 GT 1GB Silent Cell 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Desktop Graphics / Video Cards
Or on the AMD side, a 4670 passive:
Newegg.ca - HIS H467PR1GH Radeon HD 4670 1GB 128-bit DDR3 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card - Desktop Graphics / Video Cards
You could also try putting a good GPU heatsink (like a Thermalright HR-03GT) on a more powerful card for passive use, but you would need a case with decent airflow to prevent it from overheating.
Old April 13, 2010, 03:20 PM
I'll second the 4670 passive cooled. I built a budget machine with one for a customer and they love it. Not a game-crusher, but they say they can play Oblivion almost maxed and FSX on medium.
Old April 13, 2010, 03:22 PM
CoolHandL's Avatar
What about a Sapphire Vapor X 5750? 161$
www.NCIX.com
Old April 14, 2010, 03:14 AM
If you want a more powerful card then there is always the powercolor HD 5750 passive. Its not in stock at ncix, but here is a link to it (I am sure it can be found somewhere).
LINK
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Old April 14, 2010, 05:44 AM
Wurmer's Avatar
I am using the second one and I am very happy with it (them) since I am running a xfire setup. This card is silent and plenty powerful to play games if the need ever arise. One thing to note, you need a good ventilated case because they do produce quite a bit of heat. I have not tried other passively cooled GPU but I assume that it should be the case with other similar product. A less powerful GPU will produce less heat and this might come a none issue.
Old April 14, 2010, 06:44 AM
Any of Sapphires Vapor-X or Toxic line would suit your needs very well with much better performance then passively cooled cards. I can't even hear my 5850 Toxic, virtually silent even under full load.
Old April 17, 2010, 09:10 AM
Sui's Avatar
Sui Sui is offline
Thx all... most of you suggested ATi ones and how would you compare those with this?
ASUSTeK Computer Inc.
Old April 17, 2010, 11:10 AM
Looking at the specs, that 240 looks like its been neutered pretty badly, I'd say go with somebody's suggestion here and not the Asus. Performance wouldn't be significantly better than your 8400 IMHO, whereas pretty much everything else mentioned here would give you a noticeable boost.
Tags
gpu , passive , pci-e , slient , video card
looking for PCI [not PCI-E] GPU with at least Shader model 3.0 Psycho-Designs Video Cards 5 March 13, 2010 08:48 AM
PCI-E GPU for HP Desktop geokilla Video Cards 15 June 15, 2009 03:09 PM
PCI GPU CanadaRox Video Cards 0 January 28, 2009 09:38 PM
Where's the GPU market at? Lima Video Cards 8 November 24, 2008 10:46 PM
