  #61 (permalink)
Old October 30, 2007, 08:38 PM
Mibs's Avatar
Skymtl how hot do these things get anyway? I'm skeptical about going for a single slot cooler when there is no aftermarket cooler available right now. After spending two years with an x1900 that got up to 80C and a tiny fan that was louder than everything else in my pc I don't want to have to go back to that. If they made something like the HR-03 for these (which I have now) it would be great.
Intel C2D E6750 @ 3.52 GHz // EVGA 680i SLI Rev. A1 (P31) // 4 GB OCZ Platinum 800 MHz 4-4-4-15 // PC P&C Silencer 750 Quad // Antec P180 // EVGA 8800 GTS 512 // Samsung Syncmaster 226bw 22" LCD
WC Loop: D-Tek Fuzion V2 // Danger Den Maze 5 // Swiftech MCP655 // Swiftech MicroRes // Thermochill PA 120.2 + 4 x Noctua NF-P12
  #62 (permalink)
Old October 30, 2007, 08:58 PM
Review of XFX will be up shortly from me. Just updating some drivers and screenshots of old setup first.
  #63 (permalink)
Old October 30, 2007, 09:02 PM
magictorch's Avatar
Default magictorch
will be interesting to see how it handles the crysis demo after your last run with 7800
  #64 (permalink)
Old October 30, 2007, 11:27 PM
Originally Posted by enaberif View Post
Do you think using a 400w power supply for only the video card will work? I've got a sparkle 400w power supply and I'm thinking of tossing it onto my 8800 GT
You'll have to clarify, as I am unsure if you plan to power the video card by using an ATX power supply with no other components? The 8800GT (G92) is a fairly power efficient GPU, but to power it alone with an ATX power supply would require the "paper-clip" technique.
  #65 (permalink)
Old October 30, 2007, 11:39 PM
Paperclip with a 400w power supply = no go! :(
*sigh* my night is not a good one.
  #66 (permalink)
Old October 30, 2007, 11:46 PM
The term is used for shorting out the green "PS_ON" pin with a ground pin. This causes the ATX power supply to power on. It's not a recommended way of powering devices, but a quick test to see if the power supply will turn on.
  #67 (permalink)
Old October 31, 2007, 12:10 AM
Any opinions on whether a Thermalright V1 would be able to cool this thing?
I have it cooling a 7800GT right now (about 68-70 Celsius after several hours benchmarking at full load, about 42 idle) with an undervolted 80mm fan on it...but I suspect the 8800GT will produce more heat.
  #68 (permalink)
Old October 31, 2007, 01:26 AM
Pic of xfx 8800 GT installed.
  #69 (permalink)
Old October 31, 2007, 09:38 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
PLease note that the discussion for the Antec TPQ has been moved here: Antec TPQ Problems Discussion Thread Antec reps have been alerted to the thread and they will be watching it for additional info about the problem
  #70 (permalink)
Old October 31, 2007, 07:20 PM
JayDee
Guest
Posts: n/a
Great job SKYMTL
Nice to have an affordable alternative if my 8800GTS 320mb should fall short in the future.
Can't wait to see what that new 8800GTS version does when it's OC'd as well.
I can only wish that GPU manufacturers would follow the lead of CPU's and offer better performance AND make the product more energy/heat efficient at the same time. The AMD A64 and the C2D have proven this can be done and I really hate the way these GPU's gobble up the juice.
Samsung YP-S5 Review Comment Thread SKYMTL Audio 6 March 30, 2008 11:53 AM
Comment Thread for EVGA 8800GTS (w/ 112SPs) Review SKYMTL Video Cards 26 January 30, 2008 02:35 AM
Thermaltake TMG A1 Review Comment Thread SKYMTL Water Cooling 5 January 16, 2008 09:14 PM
Comment thread for Thermalright HR-03 Rev.A Review 3oh6 Water Cooling 5 November 6, 2007 12:09 PM
