Old March 30, 2010, 04:27 PM
zc1 zc1 is offline
I have the Sapphire one and have had no issues with it.
My Rig
ENGINE: i7-4770k on Z87X-UD5H // Zalman CNPS12X Heat Sink // 16 GB Vengeance DDR3-1600 MHz
ECU: Win 8 Pro, Kingston HyperX 120 GB SSD
FUEL PUMP: Corsair AX1200i
HUD: Asus GTX 690 w/ 3x Asus MX279H
CHASSIS: Silverstone FT02B-W
1/4 MILE TIME: ?
Old March 30, 2010, 04:38 PM
I ordered the dell last week and had it in 2 days.
Old March 30, 2010, 08:10 PM
kyle_L's Avatar
yes an active display port adapter is needed, i do notice the odd flicler of the screen on the display port monitor but it happens at random and not that often. if you got any other question let my know.
Gotta Love Timmies Coffee.
Old March 30, 2010, 08:35 PM
CMetaphor's Avatar
Quadfather
Originally Posted by Digikid View Post
Hmm.....the reviews on the Dell site mention something of a power issue or something to that extent for the Dell Adapter.....
You have had no issues such as that?
In some cases the power from the USB port that the active adapter will not be enough to keep the adapter on, causing the connected monitor to loose signal at inopportune moments. Fixes can be to either plug into a different port and try it there, or get a AC wall-wart to USB made for charging and plug it into there. I use the latter option (never tried without) using a 5v 1000mA AC-to-USB adapter.
Old March 30, 2010, 08:43 PM
kyle_L's Avatar
hmm.... i will have to try that, all i need is an usb extention cable.
Old March 31, 2010, 03:28 AM
Digikid's Avatar
Never saw those before CMetaphor. Where can I get one?
Old March 31, 2010, 05:26 AM
CMetaphor's Avatar
Quadfather
Radiosha-- i mean "The Source", lol. Belkin Dual USB Charger | Cables, chargers & adapters | TheSource.ca
But you can probably find one thats less expensive easily, that's only an example. Still though, I'd probably recommend At Least 500-600mA, i just took a 1000mA one to be safe, heh.
L3 cache is unlockable on Athlon II X4 620, benchmarks galore Unknownm Press Releases & Tech News 0 August 27, 2009 02:15 PM
[FS] Q6600 G0, video cards galore and misc !! Xilikon Buy/Sell & Trade 17 May 16, 2009 06:46 PM
AMD-V Motherboard Support Confusion kingnubian CPU's and Motherboards 3 March 14, 2009 12:45 PM
ZOMG San Ace Galore cyberspyder Air Cooling 4 August 22, 2008 12:27 PM
FSB and memory confusion! Mibs Overclocking, Tweaking and Benchmarking 5 July 13, 2007 09:27 AM
