Old March 21, 2010, 11:34 AM
Question Upgrading low end system
Hello all,
I am planning to get a new card to up grade this low end system.
Currently 8600 gt, 400w PSU, Windows XP.
What is better: 4650 DDR3 or 4670?
Thanks for your help.
System summary :
Mainboard : Gigabyte M61VME-S2
Chipset : nVidia 6100V
Processor : AMD Athlon 64 X2 3600+ @ 2000 MHz
Physical Memory : 4096 MB (2 x 2048 DDR2-SDRAM )
Video Card : NVIDIA GeForce 8600 GT
Hard Disk : ST380815AS (80 GB)
DVD-Rom Drive : TSSTcorp CDDVDW SH-S203N
Monitor Type : LG Electronics L1752TX - 17 inches
Operating System : Microsoft Windows XP Professional 5.01.2600 Service Pack 3
DirectX : Version 9.0c (May 2009)
S.
Last edited by Simfriend; March 21, 2010 at 12:49 PM. Reason: Added System Summary
Old March 21, 2010, 11:42 AM
i wouldnt get anything lower than a 4870 or gtx 260, what monitor do you have? and what games do you/will play?
Old March 21, 2010, 11:45 AM
gingerbee's Avatar
4670 but i would look at 5750 or a little lower think more about just get a 5XXX series card why buy old tech is what i mean.
specs, res & games you play helps
Old March 21, 2010, 12:00 PM
Babrbarossa's Avatar
hehe- I have a brand new sapphire vapor-X 5750 1Gb here that I need to get rid of- i ordered it for a friend without knowing that his computer was an ITX and found out too late to send it back.
It's a DX 11 card unlike the 4XXX series and a souped up cooling on it
psst, wanna see my binder?
Old March 21, 2010, 12:16 PM
How much? Ship to Victoria, BC?
Old March 21, 2010, 12:24 PM
Mr. Gruntsworthy's Avatar
It would help to know the RAM and Processor.
MAIN RIG:
Case: Antec 900
CPU : Intel E8400 45nm Core 2 Duo @ 3GHz 1333MHz FSB
RAM : 4GB DDR2 800MHz (OCZ Platinum)
HDD : Main: 120GB SSD (OCZ) Media: 500GB (WD) Storage: 1TB (WD)
GFX : HD4850 (512MB)
PSU : 610W PC Power Silencer
MoBo: Asus P5Q SE
View : Acer H213H 21.5" @ 1920 x 1080
Oshawa Deathmatch Community -- An open group for Durham/Toronto Airsoft, Paintball, and Nerf players. Come join!
My Game Dev website: http://mikeseguin.webs.com/
Old March 21, 2010, 12:35 PM
Hi,
Gigabyte GA-M61VME-S2 rev.2 mobo,
Type : AMD Athlon 64 X2
Internal Specification : AMD Athlon(tm) 64 X2 Dual Core Processor 3600+
Information SPD EEPROM (A0) :
Manufacturer : Corsair
Part Number : CM2X2048-6400C5
Serial Number : Unspecified
Type : DDR2-SDRAM PC2-6400 (399 MHz) - [DDR2-800]
Hope this is of use
S.
Old March 21, 2010, 12:36 PM
PM sent
Old March 21, 2010, 02:06 PM
if you're going to upgrade, actually *upgrade* - get something current generation, and decently powerful.
a 5750 or 5770 , since you seem to like ATI.
if budget is an issue... save up. buying old mid-low end cards continuously doesn't help.
Go low end or high end system? ITaoI New Builds 11 December 18, 2009 01:42 PM
What path to go low to high end system ITaoI CPU's and Motherboards 0 October 5, 2009 05:16 PM
FS: Low end PC 2 anabioz Buy/Sell & Trade 6 November 1, 2008 03:48 PM
FS: Low end PC anabioz Buy/Sell & Trade 10 November 1, 2008 11:07 AM
