Old March 20, 2010, 06:17 PM
MarkOne's Avatar
Default play game on a HDTV
hi I have a sharp with a resolution of 1920 x 1080 can I plug it on the hdmi or I have to use the dvi of my 5870 for play game
of course I want the best of it
Old March 20, 2010, 07:03 PM
should work fine with the hdmi though some Tv's sometimes require a certain hdmi input on the tv. Example, my samsung has three hdmi input but only the hdmi 1 play's the resultion is use 1360x 768. So if you have trouble running 1080(unlikely) just try another input
Old March 20, 2010, 07:41 PM
HDMI will work fine for 1080p (1920x1080). I have my TV running the same resolution from my computer (use it for watching movies) via HDMI.
Old March 20, 2010, 08:08 PM
Lima's Avatar
I am on a 4890 and it works great for me too, sound and all. Even with XP.
My TV defaulted to 1080i but, when I set the refresh rate to 60 Hz, it then started outputing 1080p.
Old March 20, 2010, 08:19 PM
Originally Posted by Lima View Post
My TV defaulted to 1080i but, when I set the refresh rate to 60 MHz, it then started outputing 1080p.
You mean 60Hz .
Old March 20, 2010, 08:27 PM
Lima's Avatar
Originally Posted by Zero82z View Post
You mean 60Hz .
Yup. Thanks for pointing that out, I didn't notice.
Old March 21, 2010, 08:03 AM
Yes it work great. It's like a big monitor. I game with my PC on my projector. Make Xbox games look like PS2 :) LOL!
Old March 21, 2010, 09:41 AM
... does it matter either way you connect it? Hdmi just transmits sound as well.
Old March 21, 2010, 09:47 AM
gingerbee's Avatar
yup been using my hdtv for games for a long time gone from vga to dvi/hdmi know all worked just great.
Old March 21, 2010, 01:52 PM
Arinoth's Avatar
Doesn't matter, i've transmitted through both, and actually depends on if you have the half or full dvi output too. I run dvi to hdmi with a proper dvi to hdmi cable that transmits both the audio and video over, but you can still do video dvi to hdmi as well
Left 4 Dead game play vids misterlarry Gaming 25 November 13, 2008 09:06 AM
Far Cry 2 game play vids! Killswitch Gaming 7 October 8, 2008 03:34 PM
Let's play a game about my new build, this or that? donimo Overclocking, Tweaking and Benchmarking 4 December 14, 2007 11:45 PM
What Game's do You Play? Supergrover Gaming 51 December 12, 2007 02:02 PM
