Old October 19, 2007, 04:37 PM
mattydies's Avatar
Default What is Stock Voltage?
What is the Stock Voltage for my Card? I want to know so I can work on over clocking :)
My Video Card is an MSI NX7800GT - 256MB PCI-E
Matty
Old October 19, 2007, 05:59 PM
JD JD is offline
You can't exactly change the voltage easily anyways without either modifying the card's BIOS or physically modifying the card.
You can adjust the Core and Memory clocks by using RivaTuner or ATITool.
Old October 19, 2007, 06:01 PM
mattydies's Avatar
I can up the PCI-E Voltage in my bios.
ASUS P5N-E (650i)
Stock BIOS BTW.
It lists Voltage's and I pick which I want to run. NOT how many mV I want to increase it.
Old October 19, 2007, 06:03 PM
sswilson's Avatar
That's the voltage to the slot, not to the card.
Old October 19, 2007, 06:45 PM
mattydies's Avatar
ahh...
Thank-you very much for the info.
The Video card will retain stock voltage for now then.
Should I just leave the PCI-E Slot voltage as "Auto" ???
Old October 19, 2007, 06:48 PM
Originally Posted by mattydies View Post
ahh...
Unless you are overclocking yes leave it as auto.
Old October 19, 2007, 07:10 PM
mattydies's Avatar
Thanks.
Any suggestion for when I try over clocking my video card? (Im sure I will end up trying soon enough)
Old October 19, 2007, 07:15 PM
Thanks.
What OS are you running? Cause if its Vista you will have little luck with stupid ntune or rivatuner because Vista doesn't like unknown programs to start up at boot.
Old October 19, 2007, 07:25 PM
mattydies's Avatar
I am running XP Home. (32 bit)
Old October 19, 2007, 08:48 PM
sswilson's Avatar
ahh...
I'm not sure if many folks overclock their PCIe slots (other than the fairly traditional 101 vice 100 just to ensure that the slot is freq. locked) anymore. I did some trial and error stuff a while back using info I got from Ntune (this is a long while back... haven't used Ntune in a couple of years at least) and found an actual FPS benefit in 3DMark testing to pushing the speed up.
Most overclocking guides I've seen though suggest that overclocking the PCIe slot by much will hamper CPU overclocking attempts.
Over Voltage a35599 Overclocking, Tweaking and Benchmarking 6 February 26, 2008 09:21 PM
Overclocking question (Voltage) Wasza Overclocking, Tweaking and Benchmarking 2 January 22, 2008 10:28 AM
Do i need to remove V-droop with the voltage dampner magictorch Troubleshooting 1 January 19, 2008 06:16 PM
Voltage and PSU monitoring software BALISTX Power Supplies 10 September 5, 2007 05:05 PM
max dc voltage in north america? Fr0sty Power Supplies 6 August 12, 2007 08:46 PM
