Old February 26, 2010, 10:22 PM
IRQ Conflict's Avatar
Originally Posted by Digikid View Post
So? DX11 is fine and all but it is not REALLY necessary.
Get an Xbox/PS3. Call it a day.
Old February 26, 2010, 10:36 PM
belgolas's Avatar
the 5870 isn't going to be fast enough for a lot of DX11 features on a 30" monitor. The dual 280's is a much better deal. The ONLY thing the 5870 is better at is DX11 which basically the only new feature is tessellation.
Sponsor a child!
Fight poverty.
Qoute by Perineum
"ID10T. I just BETCHA he's got 9 toolbars on his web browser right now."
I'd get the HD 5870 unless you want to try and save $50 in the short term and go for another used gtx 280 at $180. Over a year with the PC on all the time the 2 x gtx 280's would use another $50 of electricity at idle anyways.
Old February 27, 2010, 02:55 AM
Silvgearx's Avatar
Dude, Please see his system spec. You might want to look at it as a whole.
He only have 620W psu gtx 280 pulls at least 200W under load + that 9550 is likely overclocked so it will use at least 100W, 200+200+100 thats 500W right there, forget about that water cooled CPU + rams, HDDs. Even if he has 90% efficiency PSU he only have 558W disposable.
If gtx 280 SLI route is taken, he is probably gonna need a new PSU something that is rated at 750W or higher.
As for "the new shit" from nvidia, We still don't know HOW MUCH faster it will be compared to the old gtx 285, maybe a mere 40%! We won't know till march 26, And all we seen up till now were wooden screws. And when it does come out, most average consumer are gonna need to break the bank due to low supply and high demand. Just like how some of the PS3 were priced over $1k.
Anyways jumping from a gtx 280 to 5870 will give you somewhere around + 30% in performance, and lower power by a bit.
Old February 27, 2010, 03:56 AM
You contradict yourself. And your wrong to boot.
Old February 27, 2010, 06:34 AM
MarkOne's Avatar
gaming is not REALLY necessary
Old February 27, 2010, 07:54 AM
Scalings an Issue in SOme games... ATI Drivers are an issue for every game ... GG
ATI=Benching card.
Nvidia=Real life.
MHO...
I get 110 FPS Avg in BC2
My Buddies 5870 gets 80 FPS.
I know the 5870 is stronger of a card, Why is it bad at BC2... DRIVERS.
Old February 27, 2010, 08:13 AM
Question
Wow, thanks. I am glad you did consider my system spec. and that is why I put it there in the first place!
To begin with I want to mention that I am looking to buy, in either case, a used card. GTX 280 SC runs about $180-$200 and a used 5870 about $300, if I am lucky, but I think for sure at $325 (or I can buy a new in box, after Bing CashBack for ONLY $360!!).
So if I go with the 5870 I'll be selling my 280 SC which would result in a balance of $100 - $150 - clsoe to having two 280s.
Here is another deal I have come across: 2 EVGA GTX 285 FTW for $500.00! (as if I was not confused enough.)
But if I am going to spend $500 I might as well go for the 5970 at about $600!!!!! Between the DUAL SLI 285s and 5970, the 5970 is the better choice, no?
But, you are right, with the 5870 I will NOT need to change my PSU but with the 280s or the 285s I would have to change my PSU!!
Motherboard: EVGA nForce 790i Ultra SLI
BIOS: P10
CPU: Intel Core 2 Quad Q9550 Yorkfield
CPU Cooling: D-TEK FuZion v2 WB
Case: Koolance PC2-601 (Exos-LT (1/4" ID))
PSU: Enermax Liberty ELT620AWT 620 Watt
Dimms: Patriot Viper 4GB (2 x 2GB) DDR3 2000 - 9-9-9-24
Graphic Card: EVGA GeForce 280 GTX SSC
OS Drive: Crucial Solid State Drive Model No. CT256M225 (256GB)
OS: Windows 7 Pro x64
Monitor: Dell 30" 3008WFP Rev. A03
  #19 (permalink)
Old February 27, 2010, 10:22 AM
A GTX280 uses about 180W under typical gaming load. And your understanding of efficiency is incorrect. A 620W PSU has 620W of power available. However, you're right that he would basically need a new PSU if he went with dual GTX280s.
ATI=Benching card.
Nvidia=Real life.
MHO...
I've had more issues with nVidia drivers than I have with ATI drivers, and I've been using them both extensively for years. As for those performance differences, what are your full specs and your friend's specs? And are you running at the same resolution and settings? If he's running in DX11 mode, that would explain the performance differences since apparently there are known performance issues with that in the beta.
Yes, the 5970 would be the better choice.
  #20 (permalink)
Old February 27, 2010, 10:34 AM
Its so refreshing to see so much knowledge on this board! Thanks guys!
BIOS: P10
[FS] Sold AdoP Buy/Sell & Trade 19 July 18, 2011 06:17 AM
XFX ATI Radeon HD 5870, How Loud ? JORD4N Video Cards 2 October 13, 2009 07:24 AM
ATI Radeon HD 5870 Pictured and Detailed FiXT Press Releases & Tech News 75 September 14, 2009 10:08 PM
GTX 280 vs GTX 280 SLI...Benches rjbarker Video Cards 39 November 16, 2008 04:36 PM
