Old February 22, 2010, 07:01 AM
JD JD is offline
Originally Posted by 5ILVgeARX View Post
So that board is a MSI K9A2 Platinum. Thats a pretty solid setup you got, so instead of buy a new gpu, why not try to get the CPU to clock at 2.8ghz-3.0ghz?
Darkfall doesn't seem to be that graphic hungry, even for a single 4850.
It's an original Phenom though, no amount of overclocking is really going to help IMO. They just weren't good CPUs to begin with.
About a 15-20% gain changing CPUs (that's in a system with a GTX280), so I think it would be a fairly worthwhile upgrade.
Can grab the X4 945 for $159.99 and a HD5850 for around $300? I think that's the better route, but that's just me.
Old February 22, 2010, 12:11 PM
I'm not really super savvy (as you might have noticed) and I'm wary of overclocking, this my computer has had some issues with overheating in the past. Is overclocking a CPU something that is fairly simple to do?
Darkfall isn't graphic hungry, if there are only like 50-100 folks on the screen. It is when you get beyond that the framerate starts to drop off sharply, and recently I've attended a lot of fights with 500 people running around where my FPS was about 10, which makes it really hard to fight and aim in.
Old February 22, 2010, 10:32 PM
Raserei408's Avatar
What kind of cooler are you using? Is it a stock or aftermarket?
Overclocking is fairly easy if you read up a bit beforehand. As for the heat issue, you'll probably want an aftermarket sink if you're doing any kind of OCing beyond stock voltages.
"If dancing is sure to result in failure then you must dance anyway."
Lo Mein said that, and I think he knows a little more about dancing than I do pal, because he invented it! Then he perfected it so that no man could best him in the club of honor.
Then he used his prize money to buy two of every whore on Earth. Then he herded them all onto a boat, then they all beat the crap out of every single one of him.
Old February 22, 2010, 11:54 PM
of note:
MICRO-STAR INTERNATION MS-7376 1.0
the 1.0 is stating the motherboard revision number.
just for future reference.
Old February 23, 2010, 01:17 AM
Silvgearx's Avatar
For starters I think it must be the CPU thats holding you back. For now why not try to drop your details to low and see if it still give you massive lag. If it does its the CPU and your better off getting a new CPU.
If you still get the same results then you can start thinking about a new GPU.
Since your not comfortable overclock, I advice you not to touch the settings. Best you just get some new parts
Old February 24, 2010, 10:51 PM
Well, my 5870 arrived, and I'm fairly happy with it for games like The Witcher and Dragon Age. Better FPS, at about 40c cooler than the previous crossfire setup. Darkfall is definitely better, but I think the CPU is bottle-necking the graphics card (or Darkfall is just huge on the CPU calculations). Would the X4 945 be a good fit for my motherboard and overall setup? It is within the price range, I'm curious if it will fit in my computer properly. The 5870 itself was so large and so in charge it took a LOT effort to get it into my case.
Again, thanks a lot to all the contributors of this thread! It is a huge relief to know that what I'm buying isn't going to light my computer on fire with horrific incompatibilities :)
[WTB] PCI-E AND AGP CARDS _dangtx_ Buy/Sell & Trade 54 July 16, 2009 08:13 AM
WTB NEED Want to add to my farm ,need pci express video cards elec999 Buy/Sell & Trade 4 October 28, 2008 01:41 PM
WTB PCI-E Video card with Video out Taichan Buy/Sell & Trade 0 June 9, 2008 08:17 PM
Has anyone tried Xfire + Physics Card...3x pci-e cards. qwerty Video Cards 5 November 5, 2007 04:46 PM
24 ATI Radeon PCI-E Video Cards Benchmarked by Legit Reviews Babrbarossa Reviews & Articles from the Web 9 March 30, 2007 05:12 AM
