Originally Posted by kendallcschm i have the core at 810 and the memory at 1200.. but the shader won't go farther than 1944... it irritates me.. and i can't install rivia tuner either. it says the Rivia Tuner server is still running on my machine.. if i could get rid of that i think i could oc it even more.. i just wanna know if its worth getting aftermarket cooling or not |
talking at aftermarket cooling...my Asus run hot like hell. I have to open the case and put a 12" house fan . to throw air on it... unless a experiment member in GPU OC came to post here. I will recommend you slower you ambition on the OC of this card
By the way I like to see you start to fold
Edit....
an experiment GPU OC guy ( ST ) just comment at the same time I write my post
try is idea
