Tom's Hardware recently reported issues with ATI 5xxx series cards:
http://www.tomshardware.com/news/ATI...rash,9529.html
Tom's then reported that ATI has confirmed the issues, and is working on a fix:
http://www.tomshardware.com/news/ATI...5870,9549.html
Has anyone here run into similar issues? I did during the build of a system, but due to other factors I thought I had a faulty motherboard. In my case, I was getting some pretty bad crashes that left the screen in a pin stripe patters - my first thought was that Microsoft had finally upgrade the BSOD to a pinstriped screen of death, which is about the level of creativity I would expect from that company.
My other issues were that it seems that two of the four pieces of G.Skill memory I was using is faulty, and that the BIOS on the motherboard had been trashed during one or more of these crashes, to the point that reflashing it did not bring back all functionality.
In other words, I seemed to be facing three issues - flakey 5xxx drivers, bad memory, and a trashed BIOS.
My solution was to return the motherboard as faulty (Maximus III), pay to upgrade to a P7P55D-E Premium, and rebuild using the two known good memory modules. So far, I have had a couple of similar crashes, but no more, and the system seems pretty stable.
Anyone here encountering similar issues with ATI cards?
On a semi-related note, I had installed the 9.12 drivers for the XFX 5770 video card during the build. When the 10.1 drivers became available, I installed those, but the information part of the Catalyst control centre still says 9.12. I even uninstalled the 9.12 drivers, then installed the 10.1 drivers, and the same version still appears. Any ideas why this might be?
Thanks in advance!
System:
ASUS P7P55D-E Premium
Intil i5
Venomous X cooler with two 120MM Noctua fans
2 x G.Skill DDR3-1600 memory
2 x OCZ DDR3-1600 memory (later addition)
VelociRaptor 300Gb
Seagate 160Gb SATA hard drive
XFX 5770 video
Corsair 750HX power supply
Various Plextor and LG optical drives
