Old January 10, 2010, 02:20 PM
Default 4890 big change in temps
Hi,
I've got my HD4890 heavily underclocked for when I'm doing 2d stuff and I am noticing a a raise in temperature compared to what it normally is.
Here is the underclock:
GPU clock: 500mhz
Memory clock: 490mhz
Here are the current values:
GPU clock: 500mhz
Memory clock: 975mhz
Temperature: 69 C
What I notice right there is that the GPU doesn't underclock further when idle (it should be at 240mhz if I remember properly) and the memory... the memory doesn't do what its supposed to do.
The temperature used to be somewhere around 52-54 C with those settings (all working properly).
I recently went away from the RC version of win 7 to win 7 Home Premium, not sure if it could be linked to that.
Not too sure for how long this has been going on, but normally its not like that. Am I missing something ?
Old January 10, 2010, 11:41 PM
cozmosland's Avatar
does the 48 series not have power play where it runs the clocks at like 157 and 300?
Old January 11, 2010, 05:33 AM
It does (not exactly at those speeds), but somehow now it doesn't do it anymore and I am confused as to why.
Old January 14, 2010, 01:39 PM
bkh2's Avatar
Did you download the latest drivers from the website or are you just using the drivers that came with Windows 7? I ask because for the longest time, I didn't bother getting the real drivers since I wasn't doing heavy GPU related things and the ones that came with Windows 7 gave me max resolution already.
Old January 14, 2010, 04:31 PM
yeah, I'd try reinstalling with some new drivers.. my 4890 hasn't experienced these issues... yet.
Old January 14, 2010, 08:03 PM
Everything was properly installed but for some unknown reasons after a system restart everything went back to normal.
Old January 18, 2010, 05:28 AM
cozmosland's Avatar
hmm ok i thought it had it since i used to own one, those are the powerplay clocks my 5770 does.
Old January 18, 2010, 06:26 AM
HaDeS
Guest
Posts: n/a
One thing I've noticed about win7. If something isn't working the way it normally does. Reboot.
VRM Temps of XFX 4890 XT's Wall86 Video Cards 2 November 24, 2009 07:16 AM
XFX 4890 temps Kilauea Video Cards 2 October 22, 2009 05:39 PM
Toxic HD 4890 or Vapor-X HD 4890 AmuseMe Video Cards 10 July 20, 2009 03:54 AM
Big differences between core temps Skruch CPU's and Motherboards 5 January 25, 2009 07:34 PM
CPU temps vs Core temps sloth CPU's and Motherboards 13 October 19, 2008 12:34 PM
