Originally Posted by Smn123 So we are talking about a performance premium merely.Given that the game supports PhysX it will be more resourse effective,which means that a better ATI card will run at as well though it will,probably,need more graphics processing power.So since the 5850 is a better a VGA with substantially more computational power than the 275(even the superclocked) it should partly offset the premium 275SO has in Physx supporting games.So PhysX supporting cards don't do sth ATI cards can't,they are just more(maybe seriously more) efficient in some cases.Right or wrong?Shortly,will the 5850 fall behind 275's (Superclocked-Gigabyte) performance seriously,in PhysX supporting games?Is it only a performance lack or is it an image quality lack that is attributed to PhysX properties? |
Your understanding is not correct. PhysX performance and graphics performance are not related. Some games that use PhysX introduce extra physics effects that cannot be enabled without a PhysX-supporting card being used. Although a 5850 is faster than a GTX275, it still cannot use these effects whereas a GTX275 can. As for hardware PhysX support providing performance benefits, the issue is that without hardware PhysX, the physics calculations will be performed on the CPU and not the GPU, so the CPU would become the bottleneck in physics-intensive situations. However, that's usually not a major concern.
