Old December 28, 2009, 05:14 PM
jcmaz's Avatar
Default XFX RMA Replacement?
Hey HWC,
What Nvidia card do you think that XFX will send to me as a replacement for my faulty 8800GS?
THX
-Plato
Old December 29, 2009, 07:00 PM
Originally Posted by jcmaz View Post
Hey HWC,
THX
probably a 210gt
Old December 29, 2009, 07:12 PM
Originally Posted by BobbyLou View Post
probably a 210gt
I think you mean GT 240; the GT 210 isn't remotely as powerful as an 8800GS whereas the 240 is similar. However, it's possible that they'll replace it with a 96SP 9600GSO if they have any left.
Old December 29, 2009, 07:16 PM
jcmaz's Avatar
But my Coolink GFXChilla doesn't even fit the GT240... the GT240 isn't even on the compatiliblity list. Hopefully i'll get a 9800GT or GTS250 (which i doubt)
-Plato
Old December 29, 2009, 07:44 PM
CroSsFiRe2009's Avatar
9600gt is a more likely candidate
Old December 29, 2009, 08:51 PM
BT!'s Avatar
BT! BT! is offline
your allowed aftermarket coolers on xfx cards, so tell them in your rma ticket you have that chilla and ask if they can send something its compatible with. might be worth a try?
Old December 30, 2009, 02:27 PM
BootlegUsher's Avatar
So do they not make 8800 series cards anymore or what?
Old December 30, 2009, 03:07 PM
No, the 8000 series was discontinued quite some time ago.
Should I be upset? NewEgg RMA replacement no more? coriolis Off Topic 13 December 15, 2009 05:00 PM
Another Disapointed XFX RMA BT! Video Cards 30 November 24, 2009 04:37 PM
XFX RMA? redwagon CPU's and Motherboards 17 November 11, 2009 06:02 PM
XFX RMA Bobobear Video Cards 9 October 18, 2009 06:44 PM
XFX RMA - what are my chances? DragonFlame Video Cards 9 July 30, 2009 08:48 AM
