Old December 18, 2009, 07:13 PM
Default Card recommendations
I'm planing on upgrading my video card since I'm planing on moving from a 15" monitor to a 22" one, finally :)
Currently have a 8600GT (eVGA 512mb DDR2 version) and was wondering what cards you guys would suggest. My system specs are in my profile and I'm leaning towards the eVGA GTS 250 1GB version. My PSU has 550w and 24amps on the 12v rail. It's old so it doesn't have any of the new PCIe power connectors so I'm trying to stick with a card that only uses one 6pin.
So if you guys have any suggestions that would be great, budget is around 150$. I'm open to AMD stuff as well. Thanks
On a fun note, my 8600 was idling at 70 degrees and peaking at 100 but now that I got rid of most of the dust, it idles at 45 and games at 60
Old December 18, 2009, 08:28 PM
geokilla's Avatar
NVIDIA GTX260 or ATI 5770.
What PSU do you have? Like brand and model.
Old December 18, 2009, 08:55 PM
I think it's a generic brand although it has never failed me.
Optimax Titan Power
Model: ATX-550PS
Old December 18, 2009, 09:13 PM
Yeah, that's a piece of crap. I recommend that you upgrade your PSU to a quality unit before you think about getting a more powerful GPU. Otherwise, you may end up with the kind of explosive result you aren't looking for.
Old December 18, 2009, 09:44 PM
Arinoth's Avatar
Ah dirty power, one of the silent killers of electronics. I'd follow zero's suggestion and pick up a real power supply and then a graphics card otherwise dirty power may end up killing one if not many of your pc powers over time.
Old December 18, 2009, 09:46 PM
Or not so silent if the PSU decides to go boom.
Old December 18, 2009, 10:16 PM
Had a feeling I should buy a new PSU. Fuuuu that's 3 things I need to buy now.
Got any recommendations for a new PSU? If I get a new one I guess I can be more open to different kinds of gfx cards.
Edit: been checking out this one, I don't know that much about PSU
Newegg.ca - Antec EarthWatts EA650 650W Continuous Power ATX12V Ver.2.2 / EPS12V version 2.91 SLI Certified CrossFire Ready 80 PLUS Certified Active PFC "compatible with Core i7/Core i5" Power Supply - Power Supplies
Good price?
Old December 18, 2009, 10:19 PM
Arinoth's Avatar
I would say this is would be a good power supply that should be able to handle whatever you throw at it and then some and only 80$ after MIR, 100$ before MIR at their limited stock price.
NCIX.com - Buy Corsair TX650W 650W ATX 12V 52A 24PIN ATX Power Supply Active PFC 120MM Fan - CMPSU-650TX In Canada.
Old December 18, 2009, 10:28 PM
Thanks for that ^^^ I'll take a look
This is another good option if you don't want to deal with rebates: NCIX.com - Buy Antec Earthwatts 500W Power Supply ATX12V V2.2 Active PFC 80-PLUS 80MM Fan - EA500 In Canada.
[WTB] Sound card and wc video card hausner Buy/Sell & Trade 17 August 11, 2009 01:59 PM
Lan card or on board lan networking card? the killer nic wonder? NeitNJ Networking 8 July 21, 2009 12:03 AM
WTB: Video Card/Sound Card/Hard drive - Look here if u gotz some ! Flintblade Buy/Sell & Trade 4 December 4, 2008 09:27 PM
Ram recomendation slacker RAM 10 June 24, 2008 03:26 AM
Recomendation on DDR2-800MHz 2GB set BALISTX RAM 28 March 1, 2007 07:35 AM
