Old December 19, 2009, 06:53 AM
kendallcschm's Avatar
Originally Posted by Ghiness View Post
I'm planing on upgrading my video card since I'm planing on moving from a 15" monitor to a 22" one, finally :)
Currently have a 8600GT (eVGA 512mb DDR2 version) and was wondering what cards you guys would suggest. My system specs are in my profile and I'm leaning towards the eVGA GTS 250 1GB version. My PSU has 550w and 24amps on the 12v rail. It's old so it doesn't have any of the new PCIe power connectors so I'm trying to stick with a card that only uses one 6pin.
So if you guys have any suggestions that would be great, budget is around 150$. I'm open to AMD stuff as well. Thanks
On a fun note, my 8600 was idling at 70 degrees and peaking at 100 but now that I got rid of most of the dust, it idles at 45 and games at 60
i too have the same problem.. i went for the 250GTS...
this is the one i got:
Newegg.ca - EVGA 01G-P3-1158-TR GeForce GTS 250 1GB 256-bit DDR3 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card - Desktop Graphics / Video Cards
Old December 19, 2009, 09:21 AM
What problem did you have? How's the card working out for you?
I'm probably going to get the Corsair TX650W unless there is something better/deals. Thanks a lot guys.
Old December 19, 2009, 10:23 AM
Can't go wrong with it.
Old December 19, 2009, 10:25 PM
geokilla's Avatar
Go with the Corsair TX650W or if you want modular, Cosair HX520W.
Since you're getting a new PSU, still getting that new GPU?
Old December 20, 2009, 09:39 AM
I'm not going to bother with modular so I'm going for that Corsair PSU. Since this opens up more GPU options (PCIe pins and power) I might consider some other ones. Will update when I get the PSU installed.
[WTB] Sound card and wc video card hausner Buy/Sell & Trade 17 August 11, 2009 01:59 PM
Lan card or on board lan networking card? the killer nic wonder? NeitNJ Networking 8 July 21, 2009 12:03 AM
WTB: Video Card/Sound Card/Hard drive - Look here if u gotz some ! Flintblade Buy/Sell & Trade 4 December 4, 2008 10:27 PM
Ram recomendation slacker RAM 10 June 24, 2008 03:26 AM
Recomendation on DDR2-800MHz 2GB set BALISTX RAM 28 March 1, 2007 08:35 AM
