I just purchased this HD 4670
NCIX.com - Buy ASUS Radeon HD 4670 512MB DDR3 PCI-E DVI HDMI VGA Video Card - EAH4670/DI/512MD3 In Canada.
I'm running XP 32-bit Home on an X2 4600+ with 2GB on this motherboard
ASRock > Products > AM2NF6G-VSTA
I'm also using a SyncMaster 2343 and currently using a 350 Watt Power Supply.
I followed all the instructions in the quick setup guide and when I plugged everything back in and turned my computer on it would get to the desktop and say found new hardware, looking for drivers and then reboot and would do the same thing every time without fail. I originally plugged in the DVI plug as I've never used one before, but changed that to the older plug and the same thing happened.
It wouldn't allow me to do anything like look for drivers or anything it would just get to that spot and reboot. I'm using the integrated video and audio from my motherboard and I neeeeeeed help! I'm completely clueless when it comes to this and I've never used a seperate video card with a seperate GPU.
I'm going to need step by step instructions if anyone would be so kind as to help.
