Old December 15, 2009, 09:10 PM
DTI DTI is offline
Default P6X58D Trying get crossfire working 5870
When installing 2 5870 in a P6X58D MB do i have to change anything in the bios.
Ran 3Dmark6 on both cards separately each card scored 18700 but when done in crossfire they scored
19700 is that normal.
Do I install 1 or 2 bridges Thanks C
Old December 16, 2009, 12:10 AM
Oversized Rooster's Avatar
No BIOS setting is necessary. 1 CF bridge is enough. A second won't "add" any performance.
3DMark06 is hardly the benchmark to use for testing a CF setup although yes, when I had CFed to 4890 cards, I also got some mediocre 1000-1500 point bump.
Try with 3DMark Vantage and most importantly, install Fraps and run some recent games. Just watch the FPS.
Machine: Intel 6800K | Asus X99-E | 32GB Corsair DDR4-2666 | 500GB Samsung 960 EVO NVMe | 6TB WD Black | 2 x 4TB Hitachi 7K4000 | Corsair 750D | Seasonic XP-860 Platinum | 4GB GTX 970 G1 Windforce | 2 x 27" Samsung S27D390HS PLS | Win10 Pro 64-bit
Old December 16, 2009, 05:46 AM
IRQ Conflict's Avatar
Really? Things have changed since my X1950 Pro's haven't they.
Old December 16, 2009, 06:40 AM
Dr_BenD_over's Avatar
Fallen Folder
Really.
ORB - Compare 1 Bridge
ORB - Compare 2 Bridges
The default 06 bench is massively bottlenecked by the CPU speed.
All's well that's Haswell
Old December 21, 2009, 12:19 AM
DTI DTI is offline
pic with crossfirex the space between the cards is about 3/16 will that cause a problem with cooling or is this normal with all mother boards
Old December 21, 2009, 04:24 AM
Fallen Folder
The inside card will probably run a bit warmer, but I've always found card #1 to run hotter anyway, even if it has better cooling. I specifically look for motherboards with at least 2 slots between between the x16 PCI-E slots to give cards more breathing room. It's probably not easy to get at the locking clip with the cards that close.
Old December 21, 2009, 06:23 AM
I think the fans can get air from the rear ports as well. My old Badaxe2 board has their PCIe slots close like that but I only ran single slot cards in it. Hanners over at Elite bastards has a setup that is similar and doesn't report any problems with it.
Old January 16, 2010, 05:07 PM
DTI DTI is offline
This might sound stupid the other day I stop by the computer store looking for hard drives instead I purchased a another 5870 why I don't know
I do remember asking the guy if I could max crysis out on very high with 3 way crossfirex, for sure he replies .So this is where I need some advice
crysis benchmark with 2 cards average 45 frames 3 cards 45 frames the same, is this P6X58D premium mobo not the right one
3Dmark Vantage 2 cards 21500 3 cards 25000 Thanks C
Old January 16, 2010, 06:44 PM
bojangles's Avatar
Crossfire/SLI doesn't scale linearly, let alone the software developers don't code for more than two usually. Two cards is the sweet, after that, it's luck of the draw.
Old January 16, 2010, 09:18 PM
rjbarker's Avatar
Surprising man.....3 x (ancient old) GTX280's yields me about 34k in Vantage.....oops..forgot, thats with PhysX enabled, don't think that option is available with ATI.
Firestrike Extreme: 21.452
MARK 11: 32.530
The Latest Generation of Motherboards Shown in the ASUS P6X58D Premium Soultribunal Press Releases & Tech News 10 January 22, 2010 05:37 AM
5870 Displayport to DVI, non Dell Working! TeeJayPee Video Cards 6 November 12, 2009 03:20 PM
[WTB] 5870 BobbyLou Buy/Sell & Trade 1 November 11, 2009 07:22 PM
New and Not sure this is working. l-lunter HardwareCanucks F@H Team 14 April 21, 2009 03:41 PM
HIS 4850 ICEQ4 Turbo crossfire or normal HIS 4850 crossfire? lanken123 Video Cards 6 October 7, 2008 09:47 PM
