Old December 14, 2009, 09:54 PM
Default what are the cheapest model gpu's that can be crossfired?
building my first build, 720p gamer rig and i'm intrigued by this dual gpu crossfire setup. Read you can save money and make 2 lower budget gpu's perform like a high end one. My goal is to make is a great 720p gamer 1360 x 768 and i figure that most higher end gpu's specialize in high resolution's that i won't need for a long while. Are there any 50-70$ graphic's card's that can crossfired for some decent 720p gaming? cheaper even if posssible. whats cheap that can be crossfired?
Old December 14, 2009, 10:00 PM
BT!'s Avatar
BT! BT! is offline
heres an inexpensive one, and it has a gb ddr3 ram :)
NCIX.com - Buy Powercolor Radeon HD 4670 PCs 750MHZ 1GB 1.6GHZ GDDR3 HDMI DVI VGA PCI-E Video Card - AX4670 1GBK3-PH In Canada.
Old December 14, 2009, 10:04 PM
BT!'s Avatar
BT! BT! is offline
and if you not dead set on crossfire then this might be something you'd like
NCIX.com - Buy XFX Radeon HD 4870 750MHZ 1GB 3.6GHZ GDDR5 PCI-E 2XDVI HDCP Video Card - HD487AZWFC In Canada.
i have one on the way for a x-mas gift for someone, seems like a good deal to me. and it has double lifetime warranty, only ati mfg to offer it as far as i know.
Old December 14, 2009, 10:12 PM
Crossfiring two low-end cards is not a cost-effective way of getting better performance. The real purpose of Crossfire is to combine higher-end cards to reach levels of performance that can't be attained by a single card. You'd be best off sticking with a single GPU, such as a 4870 or 4890 if you can stretch your budget to accommodate one.
Old December 14, 2009, 10:13 PM
jcmaz's Avatar
No point at all coz the resolution is too low. Your resolution as to be 1080 or over inorder to reap the benefits of SLI/Crossfire. Get a decent midrange card ie 4870 like what BT said.
-Plato
Old December 14, 2009, 11:14 PM
thats interesting, thanks for the heads up on that brah!!
Old December 15, 2009, 05:33 AM
Varroa's Avatar
Oh, and crossfire doesn't always equal better performance when compared to one card. Crossfire/Sli sometimes doesn't work in some games and you end up getting only one card performance. Stick with a single GPU like a 4850 or a 4870.
GAMER: Win10 Pro x64, I7 3770K (4.7Ghz) (corsair H110i), Asus P8Z77-V Pro, EVGA GTX 1080 FTW, Gskill 2 x 8 GB DDR3 1600Mhz, Crucial M4 120 GB + 256GB, Crucial M500 480 GB SSD, Mx 500 SSD, HX750W, Sound blaster Z, & Fractal Design Arc MIDI R2
Lenovo Ideapad Y510p: i7-4700MQ 2.4GHz (undervolted by 80mV), 16GB DDR3L-1866MHz, Intel GMA 4600HD / SLI'ed Nvidia Geforce GT 755M 2GB GDDR5, 240 GB Crucial SSD, 128GB M.2 SSD, 15.6" HD+ Glossy LED
Old December 15, 2009, 06:37 AM
AmuseMe's Avatar
Well if you where looking for two $70 cards, and if now you are going with one a 4850, or 4870 is for you. Or if you want the best bang-for-your-buck card, grab a 4890
Old December 15, 2009, 09:55 AM
found 50 dollar cards that can be crossfired last night, think they were 4550 or 4650
you guys sure it has no effect at 720p res? I figured 2 crappier gpu would be prime for 720p because they were designed for those kind of graphics while the 200+$ gpu's specialize in 25XX by 16XX extremly resolution's
think of how cool i'll look when i tell people that don't know much about pc's that i have a dual graphic's card setup
BIG PIMP'IN
Old December 15, 2009, 11:42 AM
Like I said already, there's no point in crossfiring two low-end cards, since you'll get better performance out of a single better card for the same price, and you won't have to deal with possible scaling issues (like Varroa said, in some games Crossfire doesn't work, so it'll perform just like a single card and not two).
Scale Model Kits in Toronto CroSsFiRe2009 Off Topic 4 July 9, 2009 07:09 PM
to keep crossfired 4850's or not? quikgp Video Cards 4 May 27, 2009 01:35 PM
I could be a model mailaw Off Topic 15 April 27, 2009 11:08 PM
Retro desktop PC amp by Quinpu model Q2 Munk Audio 3 March 16, 2009 09:25 PM
[FS] Acer Aspire One (SSD + Linux model) lemonlime Buy/Sell & Trade 3 December 7, 2008 06:17 PM
