Old September 17, 2007, 01:31 PM
magictorch's Avatar
Default 8800GTX drivers
Which seem to work best? Beta 163.44 or 163.77 or the other 162.18 for 8800series on XP 32bit.
Currently playing bioshock...yes still playing it!! Like to take my time..but have just switched to a 8800GTX and am wondering which to choose. Currently have the 163.77.
This new card seems to produce a little screen tearing during transitions from dark to light shading- perhaps its running frames ahead of the monitor?
Old September 17, 2007, 02:18 PM
Latest beta are the best and make sure Vsync is off.
Old September 17, 2007, 02:30 PM
magictorch's Avatar
Default ok
Thanks..
I had vsync switched off in the "game", but i will look at the settings in the control panel.
I am not sure about using rivatuner wiht beta 163.77 but it seems to work well enough for monitoring temps. Will try to set the fan a little higher as idle temps are 55oc.
My 7950GT was about 44oc. Cards so bloody long that my antec fan card cant get at the card intake though. well at least its sucking in some cold air from the bottom back of the case.
Old September 17, 2007, 03:20 PM
JD JD is offline
I think you want V-Sync on. It will prevent that tearing from the dark to light scenes such as in the beginning of BioShock where that guy its tearing to tear into the sphere thing.
Old September 17, 2007, 04:31 PM
magictorch's Avatar
Default dont know why
it looks smooth now. Ill have a go with vsync on and see if its ok.
Strange that rivatuner thinks the core is 594 as opposed to 600, guess bfg hasnt quite oc'd it to spec.
8800gtx Sli miggs78 Video Cards 8 March 9, 2008 09:42 AM
8800gtx + no dualview Mr. Cipher Troubleshooting 1 February 6, 2008 01:21 PM
8800gtx - any point to OC? Mr. Cipher Overclocking, Tweaking and Benchmarking 2 January 26, 2008 07:27 PM
8800GTX For $430??? Cptn Vortex Video Cards 3 December 19, 2007 08:17 PM
8800gtx and Far Cry - Rendering Issues Mr. Cipher Troubleshooting 9 December 4, 2007 04:00 PM
