Old November 26, 2009, 11:03 PM
Default over clocking 8800 gs
i've put together a new system from parts i've got and started to overclock my card.
currently it's at core 550, shader 1825, memory 800, fan on 75%
and folding away. it seems the temperature doesn't go up beyond 57 while folding. should i push it a bit more?
Old November 26, 2009, 11:23 PM
Yes! GPU's can take the heat like a Saigon whore can take the... you get the picture.
Old December 1, 2009, 11:39 PM
CroSsFiRe2009's Avatar
Interesting...nice shader clock. You can push the core way higher if you unlink by the way. Same goes for the mem. I remember my 8800gs got 675 on core, 1750 on shaders and 900 on mem if you want a reference on an asus 8800gs with accelero s1 but I may have gotten my numbers wrong :X. It was quite a while ago but yes, keep going. Even to 80 should be still good under furmark
Old December 2, 2009, 09:09 AM
jcmaz's Avatar
the cores can go up to 680. My XFX 8800GS XXX Edition is at 680
-Plato
Old December 2, 2009, 03:04 PM
geokilla's Avatar
Folding relies solely on the shaders. Core and memory speed has little to no effect. Your shaders could probably be pushed a tad higher. How many shader processors does your 8800GS have?
@jcmaz. I think your 8800GS core can exceed 680Mhz. Have you tried overclocking it some more?
Old December 2, 2009, 09:54 PM
i actually had my core and mem under clocked. but right now i'm not home where gs is and at school so thing is back on stock. probably when i go back home for christmas i'll crank it up as high as it'll go. but before i left i had eue and artifact in ATI tool so put it down to 1750 without problems.
oh and i already had it unlinked. thanks. can't wait another 3 weeks ;p
or i might push it till it burns so i can get a new gpu
Over clocking my CPU kendallcschm Overclocking, Tweaking and Benchmarking 20 November 10, 2009 12:53 AM
having issues with clocking i7 920 ToXic CPU's and Motherboards 13 August 27, 2009 07:56 PM
clocking 4870 x2 ToXic Video Cards 3 August 22, 2009 01:40 AM
Need a solid Over Clocking Ram cwestwell New Builds 16 October 9, 2008 01:13 PM
Over Clocking Ram mattydies Overclocking, Tweaking and Benchmarking 12 January 19, 2008 03:59 PM
