Old November 22, 2009, 08:22 AM
AmuseMe's Avatar
Default 4870X2 + 4870 Tri-Fire?
I was wondering if I can crossfire my 4870X2 with a 4870? I'm assuming it isn't worth it, but the 4870s are only going to get cheaper and cheaper. Will I see any performance boost at 1680 x 1050, and 1920 x 1080?
Old November 23, 2009, 05:54 AM
Dr_BenD_over's Avatar
Fallen Folder
You should be able to, it's an officially supported configuration.
I wouldn't bother though.
All's well that's Haswell
Old November 23, 2009, 06:00 AM
Chilly's Avatar
Yes, I've tried it, and it works. Decent performance boost too, I got very close to my old(sniff, I miss it) 2x 4870X2 Quad-Fire results in Tri-Fire.
Old November 23, 2009, 06:10 AM
AmuseMe's Avatar
Well, 4870's are cheap as dirt now, and I am pretty sure the Rampage Extreme x48 runs x16/x16. None of this x16/x8 or x8/x8 stuff. Hm... It wouldn't bottleneck with a Q9550 would it?
tri-sli/fire peoples? lowfat Video Cards 4 June 5, 2009 12:08 AM
4870X2 and 4870 Tri-fire PSU? TerenceJ New Builds 0 April 2, 2009 06:07 PM
Running a 4870x2 and a 4870 in tri fire? BrianHanna Video Cards 3 February 14, 2009 09:04 AM
Running a 4870x2 and a 4870 in tri fire? BrianHanna Power Supplies 6 January 6, 2009 09:49 AM
Series VS parallel: tri-fire watercooling vinister Water Cooling 4 May 2, 2008 05:47 PM
