Old November 16, 2009, 05:58 PM
JD JD is online now
Originally Posted by Supergrover View Post
Beware of the coldboot issue on the Vapor-x.
4890 Vapor-X 1GB - Cold boot issue - VGA Forums
Mines all fine, though that sounds like my buddies GTX280. Does the same thing.
I only have issues booting if I pull the power cord from my PC. If I switch off the PSU though, it boots up fine. And it's always booted fine from a normal shutdown and without killing the power.
Old November 16, 2009, 08:24 PM
FreeKnight's Avatar
I've been immensly happy with my Vapor-X 4890. It's nearly silent at load, has native HDMI with audio (great to hook it up the the HDTV for gaming) and stays really cool in my system. I'd second going with the 1GB card to save money, unless you're compensating for a little underpowered CPU (though if you're in an i7 with Saph 4890, you'll run everything on 'very high' :)
My System - Mimir
|- Intel i7 920 -| - Corsair 850w HX Modular PSU -|- Gigabyte G1. Sniper -|- 24GB Corsair Vengeance DDR3 -|- Prolimatech Megashadow Cooler -|
- EVGA GTX 670 FTW -|-2x Crucial M4 256GB RAID 0-|- Seagate Barracuda 3TB -|- WD Caviar Green 2TB HDD -|- Corsair 600T White -|- Windows 7 Ultimate -|
Old November 17, 2009, 12:44 AM
I guess it's just luck whether i get a card that does this or not.
Yep, that's what i liked about it, it's silent and i'm gonna connect it to my HDTV.
If i had found a 1GB Card, i would have gotten it no doubt, but sadly, there isn't any where i live.
And i'll be running an i5 so the performance should be very good as well.
Thank you.
Sapphire 4870 1G justplainmoody Video Cards 8 September 12, 2009 06:21 PM
XFX vs. Sapphire? ToXic Video Cards 17 August 24, 2009 10:22 AM
sapphire 4830 ebdoradz Water Cooling 2 June 18, 2009 11:35 PM
Sapphire HD3870 x2 anabioz Overclocking, Tweaking and Benchmarking 4 February 8, 2009 10:22 AM
HR-03 on Sapphire 4850 Jhayman Video Cards 3 June 26, 2008 11:59 PM
