Old November 11, 2009, 11:34 AM
Supergrover's Avatar
Default Forcing 3D clocks on 4890
I have a 4890 Vapor-x here that wont engage the core past 500mhz, I know it is a power managment issue but seeing as the last ATI card I had was a pci 7000 32mb radeon I am at a loss of how to force a ATI card to full 3d clocks all the time.
So my question is how do you force a ATI card to full 3d clocks.
R.I.P.
Old November 11, 2009, 11:46 AM
bojangles's Avatar
I guess it would have to be application dependent. You'll have to set exceptions for each program you want to use full power for. At least, that's what I've had to do with my Nvidia counterpart.
Old November 11, 2009, 02:28 PM
Got it, using GPU Tool to force the clocks "unsticks" the core from 500mhz.
The powersaving functions now seam to be working correctly both +/- 2d and 3d.
R.I.P.
OC 4890 DragonFlame Video Cards 1 September 1, 2009 08:44 PM
Toxic HD 4890 or Vapor-X HD 4890 AmuseMe Video Cards 10 July 20, 2009 03:54 AM
Nehalem = Low DDR3 clocks speeds? encorp Rumor Mill 4 September 14, 2008 02:42 PM
cant overclock shader clocks magictorch Overclocking, Tweaking and Benchmarking 2 February 29, 2008 08:29 AM
My 8800 Ultra/ E6600 Clocks Hillsdale Overclocking, Tweaking and Benchmarking 3 December 19, 2007 01:26 PM
