Old November 4, 2009, 12:45 AM
ultraman7k's Avatar
Default crossfire question
So i've recently discovered that 4770 in crossfire will do pretty well, and it seems like an economical way for some performance.
anyways, i was wondering if my psu is enough to handle it?
Coolermaster Extreme 550w ATX 12v V2.01 20/24 Pin ??
or am i better off at this point in maybe getting something like the 4870?
thanks!
Old November 4, 2009, 04:40 AM
MarkOne's Avatar
it's not all the game that do well with crossfire, ( or sli) it's easy to find a card that will perform more than 2 x 4770 or 2 x 4870
Old November 4, 2009, 06:31 AM
Dr_BenD_over's Avatar
Fallen Folder
I was pulling about 360W at the wall with a pair of 4770's under full load. I'd be concerned about the 16A+16A 12V rail on that power supply though.
All's well that's Haswell
Old November 4, 2009, 11:12 AM
ultraman7k's Avatar
i'm pretty much a noob at this, so i guess you're saying there will likely be problems with my current PSU? So I'm probably better off getting a single 4870 then?
I'm just looking for a cheap upgrade in the meanwhile for my graphics card from the 8600gt i've got.
Old November 4, 2009, 11:16 AM
Eldonko's Avatar
Hardware Canucks Reviewer
Probably a better idea to get a good single card over two lower ones in CF. What is your budget and current MB? I would go with a 4870/4890 or 260 if you have around $200 to spend. Will be a huge diff over 8600GT
Old November 4, 2009, 11:25 AM
martin_metal_88's Avatar
With 1 card, depend on the card, I sugest 4870 or GTX 260 and under your PSU will be fine. Short but fine.
Ask for more.
Old November 4, 2009, 11:30 AM
ultraman7k's Avatar
thanks guys, yeah i'm using the ASUS M4A78T-E mobo.
ATM my budget is preferably under $200. I'm currently leaning towards the 4870...anyone have any brands they'd suggest?
Old November 4, 2009, 11:43 AM
Eldonko's Avatar
I like XFX personally.
Xfx Radeon Hd 4870 750MHZ 1GB 3.6GHZ GDDR5 PCI-E 2XDVI Hdcp Video Card - DirectCanada
$155 - cheap
Old November 4, 2009, 11:49 AM
double lifetime warranty good service. XFX again.
Old November 4, 2009, 11:53 AM
ultraman7k's Avatar
what about the powercolor? It seems to have gotten good reviews. Does anyone have any experience with powercolor?
NCIX.com - Buy Powercolor Radeon HD 4870 770MHZ 1GB 3.6GHZ GDDR5 PCI-E 2XDVI-I Video Card - AX4870 1GBD5 In Canada.
$141 after MiR.
crossfire question ToXic Video Cards 2 August 7, 2009 12:39 PM
Q regarding Crossfire Jackquelegs Video Cards 4 March 29, 2009 02:52 PM
[WTB] Crossfire Bridge Jackquelegs Buy/Sell & Trade 6 February 25, 2009 10:38 PM
HIS 4850 ICEQ4 Turbo crossfire or normal HIS 4850 crossfire? lanken123 Video Cards 6 October 7, 2008 09:47 PM
Noob crossfire question about PCIe slots juhhe Video Cards 0 September 30, 2008 09:55 AM
