Old November 3, 2009, 06:34 PM
Default returning 5870 what to buy?
Well my 5870 has been having a problem that it whines in games. I was told by ncix tech support to rma it but they are out of stock and I don't want to wait weeks to get a bew gpu. I am either thinking of buying some evga card and stepping up to fermi but also would like a vapor x 5870 or a 5970. Which should I get and when could I expect the vapor or 5970 to be released?
Old November 3, 2009, 06:40 PM
MarkOne's Avatar
A lot of Ati card whines, now to what extend your's is doing it..... just as info ...did you power your card with the same rail , or you use 2 differents one ?
Old November 3, 2009, 06:42 PM
Truthfully no idea, I have a modular psu though i'm not to experienced with psu stuff
Old November 3, 2009, 07:59 PM
The card whining isn't really going to change. Only thing you can do is switch to a different card and hope that you don't have the same problem. For the record, don't expect to avoid it by going with an nVidia card, since those tend to whine even more than ATI ones (my GTX260 whines quite a bit, but I've learned to ignore it). Your best bet in my opinion would be to get a replacement 5870 and hope that you're lucky enough to get one that doesn't whine too badly.
Old November 4, 2009, 08:14 AM
Yea I will rma, still would like a 5970 so I may wait to rma and get a refund and buy a 5970 one they are available
Old November 4, 2009, 08:29 AM
MarkOne's Avatar
that's may be why some card do it more. ( a big MAY ) don'T know but if not on the same rail it can make a noise ( I means an electric one ) but on an other hand, it will not balance the PSU to put in on the same rail, don,t know but will like to know.. may be an other tread
Old November 4, 2009, 08:38 AM
Can't you just put up with the whine until they come back in stock?
Old November 4, 2009, 08:57 AM
martin_metal_88's Avatar
well...if she whine and you change for a Nvidia card you wont drop the problem. Nvidia are bigger whiner or sqeeler compare to ATI. I think you are better to send it to me and I send you a 4870 Keep the card and wait for more stock then send it in RMA. Be warned, I have send many time card to different palce because of this and some time they have declined the RMA, depend on the employee you get:P
Ask for more.
Old November 4, 2009, 09:22 AM
MarkOne's Avatar
I have a 4890 , it's better than the Martin 4870 Just kidding Martin have a good idea . Mine is not available anymore
Old November 4, 2009, 09:50 AM
Dude... if you're just looking for something to hold you. You're in town, who knows, you may just be up the street from my house!
Stop by my place and I'll sell you my Single Slot Sapphire 3870 for $25. Twenty if you bring me a Medium Steeped Tea with 1 milk.
Cheers!
Local_Canuck :)
Se moquer de la philosophie, c'est vraiment philosopher. - Blaise Pascal
Only costs $50 less than a 5870 redwagon Video Cards 16 October 2, 2009 11:40 PM
question of 5870 RIGENSTEIN Video Cards 4 September 27, 2009 02:07 PM
5870 benchmark unknown_66 Rumor Mill 30 September 15, 2009 08:39 PM
HD 5870 $299 Kylzer Press Releases & Tech News 0 August 24, 2009 02:37 PM
returning seagate hdd MAKAVELI Storage 5 August 11, 2008 10:15 PM
