Old October 31, 2009, 01:29 PM
Default gts 250 or gtx 260 core 216
hi , need to buy a card amd I've this two options.
ZOTAC 1GB GTS250 288-7N103-100ZT PCIE
Interface
Interface PCI Express 2.0 x16 (Compatible with 1.1)
Chipset
Chipset Manufacturer NVIDIA®
GPU GeForce® GTS 250
Core clock 738MHz
Stream Processors 128
Shader Clock 1836 MHz
Memory
Memory Clock 2200MHz
Memory Size 1 GB
Memory Interface 256-bit
Memory Type GDDR3
3D API
DirectX DirectX 10
OpenGL OpenGL 2.1
Ports
DVI 2
HDMI with adapter
TV-Out HDTV / S-Video / Composite out with adapter
VGA with adapter
General
Tuner None
RAMDAC 400 MHz
Max Resolution 2560 x 1600
RoHS Compliant Yes
SLI Supported Yes(3-way)
Cooler With Fan
Dual-Link DVI Supported Yes
Windows Vista Certified for Windows Vista
Weight & Dimensions
Weight 2 lbs
Dimensions 13.26“ X 10.23“ X 2.67“
Packaging
Package Contents ZT-20103-10P
User Manual
S/PDIF audio input cable
8-pin PCI Express Power Cable
DVI-to-VGA/D-sub Adapter
DVI-to-HDMI adapter
Game Bundle
Type XIII Century
or
GeForce GTX 260 Core 216 sc
[IMG]file:///tmp/moz-screenshot.png[/IMG]
[IMG]file:///tmp/moz-screenshot-1.png[/IMG]
GTX 280 GTX 260 Core 216 GTX 260 9800 GTX+ 9800 GT
Stream Processors 240 216 192 128 112
Texture Address / Filtering 80 / 80 72/72 64 / 64 64 / 64 56 / 56
ROPs 32 28 28 16 16
Core Clock 602MHz 576MHz 576MHz 738MHz 600MHz
Shader Clock 1296MHz 1242MHz 1242MHz 1836MHz 1500MHz
Memory Clock 1107MHz 999MHz 999MHz 1100MHz 900MHz
Memory Bus Width 512-bit 448-bit 448-bit 256-bit 256-bit
Frame Buffer 1GB 896MB 896MB 512MB 512MB
Transistor Count 1.4B 1.4B 1.4B 754M 754M
Manufacturing Process TSMC 65nm TSMC 65nm TSMC 65nm TSMC 55nm TSMC 55nm
Price Point $420 - $500 $279 $250 - $300 $200 $130 - $170
The first new the second used.
thanks
Old October 31, 2009, 01:36 PM
Jake_HT's Avatar
260 c216
http://jakeht.deviantart.com/
Old October 31, 2009, 01:39 PM
stoanee's Avatar
Originally Posted by Jake_HT View Post
260 c216
I concur.....
heatware
Old October 31, 2009, 02:10 PM
GTX260. It's much faster.
Old October 31, 2009, 02:15 PM
Arinoth's Avatar
GTX260, hands down or up
Here I am: here I remain
Old October 31, 2009, 02:42 PM
ImmaPC's Avatar
GTX 260 C216. Straight up better performance. C'mon, GTS isn't as good as GTX. And 250 isn't as high as 260...+216! Even in non-computer-geek speak, the 260 is better. :p
A10-5800K,
F2A85M-PRO
8GB DDR3-2133 CL9
2x XFX 7870
Adata SX900 256GB
Toshiba 1TB
Galaxy 1000W
Antec One
Old October 31, 2009, 03:10 PM
The GTS250 is just a repackaged version of a previous generation card. Very not worth it. GTX260 gogo.
Old October 31, 2009, 03:19 PM
thank you so much.
Old October 31, 2009, 05:03 PM
Sushi Warrior's Avatar
Failsos is fail. Not repackaged.
Old October 31, 2009, 05:09 PM
Silvgearx's Avatar
well at least you only need a single 6pin for the gts250 and its only 9inch.
400W psu with single 6pin, nvidia fanboi, the gts250 is a must.
and gtx 260 216 all the way if you can fit/power it.
Tags
gts 250 , gtx 260
ATI 4890 VS GTX 260 core 216 VS GTX 275 chang2 Video Cards 6 September 25, 2009 04:48 AM
SLI 260gtx (192 core) & 260 gtx (216 core)? Possible? Apathetik Video Cards 5 September 22, 2009 08:06 PM
GTX 260 vs. GTX 260 Core 216 performance Matt Video Cards 13 March 25, 2009 08:42 PM
